Old 03-19-2008, 07:42 PM
I think the non-comp ones will need clearanced.
The comp versions will probably fit. They also have a couple holes per valve cover for PCV valves, breathers, oil fill, etc.
Old 03-19-2008, 08:21 PM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Just got an email from Dennis, he said my covers shipped out today (pretty fast).
He said I might need to grind a little. I will post an update when the engine gets here.
Old 03-20-2008, 03:32 PM
At least you know ahead of time that there may be an issue , unlike me who spent a saterday installing the dove set up , lashing valves , and when you think your almost done ...
Old 03-21-2008, 03:28 PM
Dennis sent me the tracking info today. All is well...so far.
Old 03-25-2008, 07:40 PM
Just a quick update. The Blue Thunder valve covers from DSC arrived today as promised.
I have not been able to try them on the engine yet.
The quality is impressive.
Old 03-28-2008, 10:52 PM
I started grinding tonight. Oh...on the valve covers I mean.
Got the first one to fit, working on the second one.
Old 03-29-2008, 04:47 PM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
Nice! I thought you would have to do that. Pix please when they're "on". I may go to those for a change of pace in the future.
Old 03-29-2008, 04:48 PM
Cobra Make, Engine: Cardiac, 428 FE
Brent,
Is it the end stands on the Erson's that won't fit or something else?
I have the same Ford Racing covers but have HS roller rockers with Precision end stands. Will they fit under those covers without grinding?
I had the stock Ford aluminum covers from 428's that I had polished and there was no way those would fit the new heads and valve gear. They look nice but don't work with the new stuff.
Paul
Old 03-30-2008, 06:23 AM
Comp ones fit on pretty much everything. Factory cast 428 covers will sometimes tag on the end stands - just barely - double gaskets provide enough clearance. Factory tin covers seen to tag on the filler baffles - but clear elsewhere.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 03-30-2008, 09:49 AM
I got the extra thick cork gaskets from DSC. They are sweet! I finished up the second valve cover and everything is honky dory.
Pics when I get a chance.
Even though it was extra work, I am very happy with the Blue Thunder valve covers.
Question:
I am going to run the oil overflow tank as per original style. The Edelbrock intake has a casting provision for the hose plate but it is not drilled. Is there a way to add the hole without pulling the intake. I would hate to pull everything apart after Keith did such a nice job.
Old 03-31-2008, 07:52 AM
Here are some pics. Note the organic, unmachined nature of the grinding. This look was very difficult to replicate using the laser cutting machine.
