February 2026
  #21 (permalink)
Old 03-27-2008, 12:10 PM
767Jockey's Avatar
Son of a gun, I'm just hitting the send button on my last message when the UPS guy rings the bell with the package from Keith. Cam I'm using is:
Comp Cams #33-000-9 solid roller
Grind #FB 4220R / 4221R R112+4
Keith Craft Proprietary Grind
Gross lift .674" / .674"
Duration @ .050"
I- 255 E - 262
Lobe Separation 112.0
I'm told it's a fairly nasty cam but will still be streetable. I hope.....
By the way, just for interest regarding the other thread about Comp Cams and the wrong distributor gear, I had Keith assemble a new MSD distributor with the gear he preferred for this Comp Solid Roller and also recurve it. He sent it with a bronze gear. FWIW.
  #22 (permalink)
Old 03-27-2008, 12:13 PM
RodKnock's Avatar
Originally Posted by undy View Post
242 int / 248 exh @ 0.050" 0.645" lift (int) 0.633" lift (exh) 112 lobe separation.
I actually was talking to Keith yesterday about this cam.
It seems many FE crate engine buyers/builders opt for similar cam specs. Must be a sweet spot of some kind. I don't have a KC-built FE, but my 482 has a cam with a 245/252 duration, .630/.651 lift with a 112 LSA. I can't wait to hear what it sounds like. Someday.
  #23 (permalink)
Old 03-27-2008, 12:24 PM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
RodKnock,
You and me both....SOMEDAY!
  #24 (permalink)
Old 03-27-2008, 12:46 PM
$5,000 huh? Sure, thats the ticket, it was only 5 grand AND it came with a flying pig!
Stamped steel valve covers are more prone to leak than the cast, start grinding.
  #25 (permalink)
Old 03-27-2008, 02:31 PM
Seriously, I found a dream deal.
  #26 (permalink)
Old 03-27-2008, 03:04 PM
Burgs's Avatar
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Originally Posted by hi-tech cobra View Post
I figured that out trying to get them to fit (which they don't). They are Blue Thunder pent roof style valve covers from DCS.
They are nice pieces but they just don't fit. If I start grinding on them, Dennis will say 'no return'. So what's a guy to do, grind away or return them for some stamped steel pent roofs?
They look good, I say grind em!
  #27 (permalink)
Old 04-14-2008, 06:16 PM
Scott M Jackson's Avatar
Club Cobra Member
Cobra Make, Engine: Ford F100; 496 Shelby, MassFlo, BlueThunder, Kee-Al-TopLoader, Detroit Locker
Let's see more of 'em. The valve covers that is.
Thanks, Scott
Super Chief
  #28 (permalink)
Old 04-15-2008, 11:47 AM
More pics in my gallery.
Rate This Thread:
