November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-04-2008, 09:27 PM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Default Silicone art
If I remove the intake to drill out the breather hole on the back of the Performer RPM intake, what are some things I need to be aware of? I really hate to pull the intake because everything is perfect right now, but I want to go with the oil overflow tank as per original (CSX3020).
Also:
Is the black silicone that is so artfully applied around the intake applied before or after the intake is bolted down ?
Old 04-04-2008, 10:43 PM
thudmaster's Avatar
Regularly Offensive
Cobra Make, Engine: spf
It is put on the intake and the block before bolting it down........you better get some help.... it is not going to come off easy........
Ed
Too close for missles, switching to guns.........
Old 04-05-2008, 06:18 AM
Default It's more about letting silicone Properly setup
Hi-tech cobra Getting 2 people to set the manifold on the motor and center it is important. IMO letting the silicone setup for a couple of minutes and skin a little. The rest is about giving the silicone 24 hours to set. DON'T add any fluids to the motor like COOLANT until the 24 hours is passed. I have tryed to run the motor or a minute to build a little heat in the block and help cure the silicone faster but have found out that sometimes you get a leak, and sometimes not. Make sure the surfaces are clean and dry. Good luck. Rick Ps don't be in a hurry on this job and make the silicone about 3/8" high line. After it's fully set you can shave off the extra with a razor to cleanup the look. Put a thin coating around both sides of the coolant passages on the intake gaskets. Same let it setup for a couple of minutes before installing. Tork to spec, but start with 10 pounds, do all the bolts, then 20 pounds until you hit spec. Follow the tightening order of the bolts, going from side to side working from the middle out. This keeps the clamping force even across the whole manifold.
Old 04-05-2008, 07:09 AM
undy's Avatar
In talking to Keith's chief engine builder they do not use a torque wrench on the intake manifolds of the FEs they build. The "snug to feel" incrementally as they go around the intake in the proper sequence. They have found that with the aluminum heads that the intake bolts are prone to pulling out the threads in the heads if you torque to specs without developing a "feel" for what you're doing. I used the same methodology on mine and it worked fine. I've re-snugged a half dozen times since the intake went on with zero oil, water or vacuum leaks.
Too many toys?? never!
Old 04-05-2008, 11:48 AM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
I dont want to rain on a fellow owners parade, but wouldn't it be possible to 'dummy' the puke tank until a true need arises to pull the intake? They are a PITA to seal and it seems like a lot of chance for little reward, but I also know what happens when you get the 'fever' to build and the wild hairs start growing...
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 04-05-2008, 04:41 PM
Default How the weather Undy
Undy If you pull out a helicoil, snap a bolt or stud, rip the threads out of an aluminium head, there is going to be a problem down the road anyway. There is no way you should hurt or damage anything with the way I described above about taking torque readings down in 10 pound increments. I would also put either a lite coating of oil on the threads going into aluminium. Antiseize is another good product but throws off the torque readings a couple of pounds. I am not going to argue on ways people assembly motors, but know from not doing it right that warping on parts happens and leaks will show over time. How the weather on VA beach? It must be almost swim time. Boy I missed that beach in the summer. Rick L.
Old 04-05-2008, 05:29 PM
jdean's Avatar
I have seen KCs engines on the stands and the silicone bead they have all around the heads, ends of the intake and oil pan are really works of art. How do they do that? Mine are always kinda smeared looking.
6th generation Texan....
Rate This Thread:
