05-08-2008, 09:34 PM
Originally Posted by blykins
My bet is that it's a leaky intake manifold gasket...especially if the builder used Felpro Printoseal gaskets on it.
I find that the cheapest Victor Reinz gaskets work the best
Mike Z
05-08-2008, 11:38 PM
I would use the Victor intake gasket as well on the stock size ports. We have a gasket made for use that we use on our ported heads. The Fel-Pro has given the most trouble with the leaking. we ran into this and swapped to the gasket we are having made for us. I have seen this more over the last few years like the anti-freeze is eating on the gaskets more. Good luck, Keith
Keith C
05-30-2008, 07:21 PM
AL
427 update
We pulled the intake and can not see where the gasket is leaking. Eddie, our Ford mechanic dropped by last night and looked at everything. We can not see a problem. So we are going to remove the head and look farther. The plugs do not show a water or oil problem. But Mike did not drive it a lot after it started smoking. Lots of carbon on top of the valves. This motor has 15 to 20,000 miles on it. We noticed the Edelbrock Performer RPM heads and the 7105 Edelbrock intake do not match. I did not take pictures, but will Saturday after we go look at a RCR GT 40 in Huntsville.  Back to the 427,,,, I would say there is 3/16" to 1/4" mismatch on all the ports. Is this common for the 427 Edelbrock stuff? The intake and heads are 8 or 9 years old.
Mike dropped off the receipts for all the parts that was used in the build. I'll go through them tomorrow. Lots of high dollar stuff but maybe mismatched.
Dwight
05-31-2008, 05:29 PM
AL
427 cam question
Mike's 427 s.o. has a Crane cam part # 341191
lift----int @cam 3200------ @valve 563
-------ex ------3334----------------587 1.76 rocker ratio
cam timing
@.014 int open 36 degree BTDC close 84 ABDC duration 300 degree
ex-------89-------BBDC -------41 ATDC ---------310
cam timing----open-----------close------max lift -----duration
.050 int--10 BTDC------48 ABDC ---109 ATDC-----238
ex---63 BBDC-------5 ATDC---119 ATDC-----248
is this a good cam for a Street Cobra????
Unique with Jag 3.31 Tremec 5 speed 15 wheels
Dwight
I tried to line up all the data but it does not post the same way.*&%^^^$% maybe the cam experts can read the data. I hope! Dwight
Reason: to fix the post
05-31-2008, 05:43 PM
AL
Smoking FE
We did not pull the 427 head today. We drove over to Huntsville and looked at Keith's RCR GT 40. While we were there we explained the smoking problem to him because he has a Unique with a 427. He thinks it is rings because the smoke trail behind the car was 50 to 70 feet long indicating oil burning not water. Monday we will pull the head.
Dwight
289 / 347 with Weber's +++ Audi transaxle
Keith made his headers
06-03-2008, 07:49 PM
AL
compression check
I did a compression check today on the 427. At 100 psi I had 10% to 13% loss on each cylinders. So the rings are good and the valves are seated. Maybe a valve seal or oil ring problem? I think we are going to replace the seals and put it together and drive it this summer.
Dwight Frye algunruner@aol.com
06-11-2008, 06:49 PM
AL
head off
here is what I found in the #2 cylinder.
Question: does it need to be sleeved or just honed and new rings?
Dwight
06-12-2008, 04:19 AM
What is the bore size?
Dwight You have a couple of choises. Those 2 lines looks like the rings where not finished properly and caused the grooves. Unless something got sucked into the motor and wedged into the ring land and piston. If the block is stock, Have your machinist home out the cylinders and buy a set of custom pistons. 5- 10 thousands over. This way you can rebuild the block about 4 times before the walls get thin if this is a 427 block. You can do the same with a 428 block. It's cheaper to get custom pistons than buy a new block or sleeve it. I have .015 over size pistons for my spare 428 motor. I don't like running the bores past .030" over. The only way I do this, is to add block filler. JMO Rick L. Ps in the old days the over size numbers where .005", .015", .017" .025" .030" This gives you an idea on fixing the motor Rick. Ps shoot the installer if the rings caused the grooves. He didn't smooth the ends. Poor assembly work.
06-12-2008, 06:32 AM
AL
Rick,
The motor is bored .040" over. Wisco made the piston for the last rebuild, about 15,000 miles ago. I had a friend who owns a "old time" parts store that rebuild motors drop by and look at it yesterday. He said it look like carbon or some type of trash had got on top of the piston and cut the grooves. Maybe the motor was cranked and rev'ed up while it was cold. Anyway I'm going to pull the motor out of Mike's Cobra and get ready for a rebuild. This Cobra will not make it to the London Cobra Show this year but Mike is going with us. We always need Co-pilots.
Rick, what do you think about his cam specs? This is a street Cobra only, no racing but of course he needs respect at the red light
Dwight
06-12-2008, 08:41 AM
AZ.
Dwight,
Very hard to determine how go/bod the scratch is over the net but there may be hope. Before you can tell if it is a (go or no go) on a re-ring option you will need some hard numbers or measurements. Granted any cylinder wall defect is not ideal but as a racer for many years I have been in your shoes before and seen woorse looking clean up fine.
Double check all the spec's of this cylinder to see where you are at now and what the clearances are now. Hone the cylinder just to the point of an acceptable cross hatch for the rings and measure the new bore diameter. You have a few thou to play with here on an engine with this little wear so see if you are still in the window. You and a good machinist can determine if you are within the +/- limits or not.
Just because you can see a small remaining scratch after a clean up hone does not condemn the engine but it may clean up easier than you think. I would be checking the pistons' ring lands closely and the rings end gap for sure. It may not be ideal but you have limited options. You would be amazed at how loose some of the old race engines were set up or run and RAN WELL. Get the expertise of an old machinist to give you a second opinion. I am hoping it works out for ya. Jeff C
