Old 09-03-2009, 03:06 AM
Default Have the job done right
wrench87 Go to the FE forumn and find Joe Craine. He does a complete intake porting on the intake manifold. The intake looks like jewerly when done and flows alot better. Some of the ports are 8-35 cfm off from the rest. It's worth ever penny. His turn around time is about 1 week. This removes the lean running cylinders. The polishing of the ports also helps because of the upper dry intake we run from the FI system. Rick L.
Old 09-03-2009, 03:52 AM
undy's Avatar
The Victor series manifolds were designed for "race engine" applications by Ebok and subsequently purpose cast with necked down intake runners. That allows the manifold to fit a multitude of heads and different applications with some port matching, which is assumed to be done with a "race engine" anyway. As Barry said run your port matching 2 to 3 inches up into the runners, being aware of you pushrod hole to intake runner wall thickness. I don't like polishing the inside of already high flowing intake runners, like the Victor has. It hurts the already deficient fuel atomization and charge mixing.
My tunnel wedge was essentially the same way out of the box, necked down intake runners that required extensive port matching.
Before you button it up make sure you're not getting excessive pushrod hole to pushrod contact too. A lot of aftermarket manifolds required pushrod hole clearancing, especially with big cams 'n fat heavy duty pushrods.
Too many toys?? never!
Old 09-03-2009, 09:27 AM
Default Different surfaces for the ports
UNDY Dave if you are running a wet manifold you will have a different surface finish of the ports. Wrench is running a dry manifold, a polished surface is better for flow, smoother is better. Have tryed rough surface, with a pcv valve working at the base of a Throttle body it slows the air flow and cokes up over time. Rick L.
Rate This Thread:
