Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 11-30-2009, 07:00 AM
LoBelly's Avatar
Question Holley Trick Kit - useful?
I have a 347 aimed at about 7000rpm and a Holley 700dp (I believe - L47782?) on top.
On hard acceleration the engine currently stumbles at about 5200rpm so I shift at about 5k (not so much fun at the track day )- if I pump the accellerator it will then kick on - but I dont know for how many rpm because I wasn't sure it was a long term prospect for the engine.
The generally woeful state of 'speed shops' around where my car is means that getting parts to tune something as exotic as a Holley carby is about a 1hr drive if they're open. (and they've told me they can do the jet kit for $116 )
Consequently I'm looking at ordering a number of parts at once with a view to being able to tune the engine without undue delay caused by multiple trips to purchase the next set of Jets etc.
I am considering the Holley Trick Kit because it looks like it has a lot of useful stuff (cams, power valves, squirters etc) - but I haven't found a contents list - even on the Holley web-site.
http://www.summitracing.com/parts/HL...3/?image=large
I would really appreciate some experienced commentary on whether the trick kit and jet kit (& powervalve block off) is likely to cover the appropriate tuning possibilities.
I already have the Holley DVD and vacuum gauge (only to discover that my brother has 2 vacuum gauges )
Any other tips/ suggestions or commentary would be gratefully received.
Also - the whole size thing - have rec'd suggestions that a 750 would be a better choice...
http://www.carcraft.com/techarticles...arb/index.html
At this stage I'm not looking to change the carby - just get it running correctly and have a good base-line for comparison against the next set of carburettors
[and if reputation is anything to go by - a fall back after propelling said 'next set into the wall]
Thankyou in anticipation
LoBelly
Old 11-30-2009, 07:13 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
First thing I would do is put a set of jet extensions on the secondarys. Sounds like you're uncovering the jets. You'll also need to get the fuel float made to clear the extensions.
Jack
XSSIVE .....
Display Modes
