Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 01-03-2010, 07:08 PM
Cobra Make, Engine: B & B Cobra 5.0, Twisted Wedge-Trackheat, TKO 600
Default Adaptive Fuel Limit Reached Lean
I finally was able to start the engine in my Cobra for the first time. The engine appeared to be working perfectly as it started with the first turn of the key. The timing is set at 10 degrees advanced at idle 850-900rpm. I let the engine idle for about 30min. and and took if for a spin around the block and the check engine light came on. I hooked my reader to the ECU and it gave me a error code of 85 which according to the book is a Adaptive fuel Limit Reached Lean. I am not sure what this means or how to correct it any help would be greatly appreciated.
More detail:
302 punched out 0.30 over
Trick Flow Track Heat Intake
75mm Accufab Throttle Body
Mass Air Meter, Pro M Racing 75mm 24LB injector tuned cold air
Camshaft, Duration 283/ 291,Lift .499/ .510
Cylinder Heads, Twisted WedgeŽ 170, Aluminum, 61cc Chamber
MSD Distributor
ECU A9S for 5speed
O2 Sensors 13inches from heads (bungs are welded into #4 and #8 header tubes.
