Hello all, yep been a while but the Cobra is on the front burner now. I took a couple pics of areas I have questions about. One is the engine location; it is a stroked Aussie Cleveland that sits on the frame mounts that came with the kit. I seems to sit high and forward. From the back of the block to the firewall is 7 1/2 inches......seems like alot. I thought that the
oil filter would be an issue as it is directly over the frame bracket that locates the left radius arm but the short filter did the trick. The other is the water pump inlet; it is an electric pump and will have to make a lower hose config. What have yall done for this? I will use stainless pipe btwn the two points I believe. Thanks for any advice or help and I have no doubt there will be more questions in the future.
Jaime
now to figure out how to add pics...hehehe
