Social Groups
Cobra Manufacturer Groups
Streetbeast /Fiberfab/ CMC/ Innovative streetmachines
Rear end alingment ?!?!
User Name
Remember Me?
Password
Portal
Register
FAQ
Community
For Sale
Gallery
Calendar
Today's Posts
Search
Community Links
Social Groups
Pictures & Albums
Contacts
Members List
Search Forums
Show Threads
Show Posts
Tag Search
Advanced Search
Go to Page...
Portal
Forums
Active Topics
Advertising Rates
Journal
December 2025
S
M
T
W
T
F
S
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
Superformance
Finish Line
Hurricane Motorsports
Serpent Express
Planet Cobra
Shell Valley Classic Wheels
Eight Stack Injection
Discussion Tools
02-16-2018
11:21 AM
permalink
Haas_guy
Hoping for a little advise. I’m to the point where I’m ready to mount the body, but before I do that I figured I’d take a couple measurements. I found the rear end is 1/2 farther on the drivers side than on the passenger side. At ride height the passenger side is at 90”, the drivers side is 90-1/2”. Anyone else run into this? Car is setup for an 8.8 rear end.
I tried taking measurements from the frame, but nothing is a reliable starting point.
Any suggestions?
02-17-2018
05:53 AM
permalink
Harry Truppner
Hello Haas guy,
I would think that you would need to find that reliable starting measuring point on the frame to verify the tracking of the rear tires. Maybe finding dead center of the front cross member as the point to triangulate to equal points from the centerline of the rear axle housing. You could try locking your steering at straight and roll the chassis along a line to verify that the rear is tracking OK or not. Does your rear have adjustable links?
02-18-2018
08:46 PM
permalink
40k Later
My ride height on the drivers side is and always has been just over 1/2" higher than the passenger side. I've always assumed this to be the cutout for the wheel well was cut out more on the drivers side. Confirm by laying it on a level surface and measure. As far as side to side I don't have that issue. The only cause that I can see would be your frame may have the Control arm attach brackets located incorrectly, all four of them. To some a half inch is a mile to others, big whoop.
Just a side note. Our cars cannot fit a good sized tire in the back which not only looks anemic it also doesn't help with traction, mine are 275/45/17's and there isn't more than 1/4" clearance between the tire and the coil spring/perch. I'd like to get rid of the coils, cut the structure away, get rid of the shocks and cut out the towers and weld in an upper support and put coil over shocks on. It frees up 3" more
02-19-2018
08:16 PM
permalink
Beastly
Haas
I think you are describing a axle alignment issue. People (me included) have had to cut and reweld the control arm mount.
However- I found that I was never happy with the rear wheel location/clearance until i put adjustable control arms. At exactly 90 inches of wheel base- i found the control arm swing caused my tire to rub inside front of wheel well. My magic number was 90.75 This allowed full compression/travel of rear with no rub. Good luck -Beastly
02-20-2018
02:50 PM
permalink
Haas_guy
Beastly, 40k,
Thank you for your response.
I’m thinking the rear mounts where welded in the wrong position. Uppers and lowers. Once I set my rear end pinion angle, the wheelbase was shorter by 3/4” and there is no way possible to attach the uppers. I have the frame set and leveled on blocks in the rear, with the outside frame rails at 5-3/4” ride height. Is this too low? Everything has gone smooth with this build until now. My frustration levels are at an all time high.
Thanks
Jeff
02-20-2018
05:26 PM
permalink
Beastly
Haas,
my car is on stands as we speak or i would measure for you. Strange I have not had anyone ever mention the uppers being in wrong place but always the lower. I just measure the upper rear distance from bolt hole on frame to bolt hole on upper dif is exactly 9 inches. I post pics in a few min
02-20-2018
05:35 PM
permalink
Beastly
the lower mount is eactly 4 inches from edge to frame sorry about crappy pic
02-20-2018
05:36 PM
permalink
Beastly
upper is 9 inches from bolt hole to bole hole center.
02-21-2018
04:38 PM
permalink
Haas_guy
Thanks Beastly. I’m going to crawl back under tonight and see if I can figure out what’s wrong
Jeff
03-27-2018
04:19 PM
permalink
52chevyred
We had to totally cut & re-weld the rear mounts: they were way off. One thing I learned in 4 years: if ONE of these has a problem, they ALL have the same problem. Streetbeasts never fixed anything.
The bracket for the rack & pinion steering was "upside down": fixed that and many more things. Good Luck! This group is full of answers.
Page 1 of 2
Discussion Tools
Mark This Discussion Read
02:55 PM
Contact Us
Club Cobra Home
Archive
Top
vBSEO
3.6.0
CC Policy
Links monetized by
VigLink
