Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Hi-Tech Owners/Builders
Like Tree501Likes
LinkBack Thread Tools Rating: Thread Rating: 8 votes, 2.75 average. Display Modes
  #61 (permalink)
Old 11-03-2023, 10:52 AM
1985 CCX's Avatar
Adding structure for body mounting.
Some tubes were MIA as glass bodies were slightly different mounting
CobraBoy and mvanhorn8893 like this.
  #62 (permalink)
Old 11-03-2023, 01:27 PM
twobjshelbys's Avatar
This thread keeps showing up in the unread posts list but there isn't anything new. Last time this was due to a database error. Maybe this post will shake things loose.
CSX4005LA
  #63 (permalink)
Old 11-03-2023, 06:15 PM
1985 CCX's Avatar
I posted this today ????
  #64 (permalink)
Old 11-05-2023, 06:53 AM
1985 CCX's Avatar
Door frames epoxy coated.....
CobraBoy likes this.
  #65 (permalink)
Old 11-05-2023, 02:58 PM
xb-60's Avatar
Nice work Jeff.
Are you the welder, and is it oxy, MIG or TIG?
Cheers!
Glen
  #66 (permalink)
Old 11-05-2023, 05:08 PM
1985 CCX's Avatar
Thank you
I use a Mig, but this is gas by Joe Stafford.
Very lucky to have resources.
  #67 (permalink)
Old 11-10-2023, 11:52 AM
1985 CCX's Avatar
Setting up final tubing for structure.............
CobraBoy and Harpoon PV2 like this.
  #68 (permalink)
Old 11-10-2023, 11:59 AM
1985 CCX's Avatar
Seaming the two areas together!
There is a little bit of work but in the end it will be strong and secure.
Buzz, CobraBoy, 1795 and 2 others like this.
  #69 (permalink)
Old 11-16-2023, 08:42 AM
1985 CCX's Avatar
A little update, lots of work.....
Ready to plenish body a bit then start the wrapping process.
CobraBoy, 1795, rustyrims and 1 others like this.
  #70 (permalink)
Old 11-17-2023, 03:08 PM
1985 CCX's Avatar
Found an alloy minion in the trunk today.
He’s wrapping the body.
  #71 (permalink)
Old 11-17-2023, 03:22 PM
1985 CCX's Avatar
The end result is so close I can taste it.
Ozgur_Tan and CobraBoy like this.
  #72 (permalink)
Old 11-17-2023, 03:59 PM
767Jockey's Avatar
What's the final plan on the joint where aluminum meets fiberglass? How are you going to bond and fasten them together, and how will you keep the two dissimilar materials from cracking at the joint? I hope it all goes well for you.
  #73 (permalink)
Old 11-17-2023, 04:27 PM
1985 CCX's Avatar
Doug
Easy, industrial two part epoxy.
When testing it out the bond it is stronger than the alloy itself which will be wrapped on the tubular frame. Testing glass to alloy alone; the alloy fails (tears) before the joint fails.
It’s will be final for sure.
  #74 (permalink)
Old 11-26-2023, 02:33 PM
1985 CCX's Avatar
Bonded and setting up overnight with two part epoxy.
No turning back now.
  #75 (permalink)
Old 11-26-2023, 09:09 PM
Harpoon PV2's Avatar
The big one! Hope you got a little sleep, better then Christmas! Cheers, Dennis
  #76 (permalink)
Old 11-27-2023, 03:40 AM
1795's Avatar
It will be all ready by the time the snow melts in the spring!
  #77 (permalink)
Old 11-27-2023, 06:22 AM
1985 CCX's Avatar
Jim,
Hope so, question will be paint!
  #78 (permalink)
Old 11-27-2023, 02:38 PM
1985 CCX's Avatar
More traction today.
CobraBoy, xb-60 and rustyrims like this.
  #79 (permalink)
Old 11-29-2023, 07:11 AM
1985 CCX's Avatar
This is why handmade cars are a test of ones Will.
Fitment, we got fitment ......
CobraBoy, Alfa02 and Harpoon PV2 like this.
  #80 (permalink)
Old 12-05-2023, 12:08 PM
1985 CCX's Avatar
Rear clip on, now to the boot ......
CobraBoy and CompFi like this.
