501Likes
11-03-2023, 10:52 AM
Adding structure for body mounting.
Some tubes were MIA as glass bodies were slightly different mounting
11-03-2023, 01:27 PM
NV
This thread keeps showing up in the unread posts list but there isn't anything new. Last time this was due to a database error. Maybe this post will shake things loose.
CSX4005LA
11-03-2023, 06:15 PM
I posted this today ????
11-05-2023, 06:53 AM
Door frames epoxy coated.....
11-05-2023, 02:58 PM
SA
Nice work Jeff.
Are you the welder, and is it oxy, MIG or TIG?
Cheers!
Glen
11-05-2023, 05:08 PM
Thank you
I use a Mig, but this is gas by Joe Stafford.
Very lucky to have resources.
11-10-2023, 11:52 AM
Setting up final tubing for structure.............
11-10-2023, 11:59 AM
Seaming the two areas together!
There is a little bit of work but in the end it will be strong and secure.
11-16-2023, 08:42 AM
A little update, lots of work.....
Ready to plenish body a bit then start the wrapping process.
11-17-2023, 03:08 PM
Found an alloy minion in the trunk today.
He’s wrapping the body.
11-17-2023, 03:22 PM
The end result is so close I can taste it.
11-17-2023, 03:59 PM
What's the final plan on the joint where aluminum meets fiberglass? How are you going to bond and fasten them together, and how will you keep the two dissimilar materials from cracking at the joint? I hope it all goes well for you.
11-17-2023, 04:27 PM
Doug
Easy, industrial two part epoxy.
When testing it out the bond it is stronger than the alloy itself which will be wrapped on the tubular frame. Testing glass to alloy alone; the alloy fails (tears) before the joint fails.
It’s will be final for sure.
11-26-2023, 02:33 PM
Bonded and setting up overnight with two part epoxy.
No turning back now.
11-26-2023, 09:09 PM
The big one! Hope you got a little sleep, better then Christmas! Cheers, Dennis
11-27-2023, 03:40 AM
It will be all ready by the time the snow melts in the spring!
11-27-2023, 06:22 AM
Jim,
Hope so, question will be paint!
11-27-2023, 02:38 PM
More traction today.
11-29-2023, 07:11 AM
This is why handmade cars are a test of ones Will.
Fitment, we got fitment ......
12-05-2023, 12:08 PM
Rear clip on, now to the boot ......
