| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
5Likes
02-26-2017, 02:05 PM
Club Cobra Member
TX
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Why do I have high fuel pressure...
First let me say that this by the dash gauge, not verified by checking the pressure with a pressure gauge. But, assuming it's not the gauge...Kirkham with Southern 427. Single Holley 4160/vac secondaries (Holley #0-3310C). Both mechanical pump and electric Holley.
I've owned the car for nearly 15 years and it's always run about 6 PSI at idle with either the mechanical or the mechanical + electric. On the road, same until about 3K RPM when, under load, the mechanical pump falters, dropping the pressure to 2-3 making the car stumble. Switching on the electric pump solves that problem and the pressure returns quickly to 6 and remains there, as long as the electric pump is on. Been that way forever, but now....
The car idles and cruises at 9 PSI, e-pump off. But still stumbled until I flipped on the e-pump and then it ran great. Weirdly, the gauge then showed about 8.5...a sl. tick lower, it seemed to me. Also, my idle seemed to have dropped from about 1050 or so to 850-900...causing the car to die without increasing the idle speed back to 1050.
Any thoughts, I understand high blood pressure way better than I understand high fuel pressure. thanx steve meltzer
steve meltzer
"I may be wrong, but I'm never in doubt"
02-26-2017, 02:45 PM
AR
There seems to be some conflicting data there - in one place you said it runs about 6 psi at idle with mechanical or electric pump. And later it idles and cruises at 9 psi. Or did it used to run 6 psi in past years and now it's running 9 psi?
I assume this is a mechanical fuel pressure gage? If your pressure is falling off to 2 - 3 psi at 3000 rpm you either have a mechanical pump going bad or some restriction somewhere. Also, possibly your tank or cap is not venting and it's taking the electric pump to pull it from the tank and push it to the engine. When opening your fuel filter do you notice any pressure being released?
02-26-2017, 04:24 PM
There have been a hundred million Holley 4160s with mechanical fuel pumps on the road over the last 50 years. None of them have ever suffered from fuel pressure starvation (mine included) unless: 1) The carb is way out of whack (floats set wrong, Moraine filters clogged and spring jammed up 2) the fuel lines are too small or clogged up; or 3) the fuel pump is broken.
I would first test the mechanical pump for both pressure and volume. The way you do this is right out of the service manual. Put a new pressure gauge, petcock, and tube in line right before the carb. Run the engine and, of course, you should have 4.5 to 6.5 psi. If it passes that test, then check the volume. Spec's call for it fill a pint jar in 20 seconds.
02-26-2017, 05:10 PM
Club Cobra Member
TX
"There seems to be some conflicting data there - in one place you said it runs about 6 psi at idle with mechanical or electric pump. And later it idles and cruises at 9 psi. Or did it used to run 6 psi in past years and now it's running 9 psi?
I assume this is a mechanical fuel pressure gage? If your pressure is falling off to 2 - 3 psi at 3000 rpm you either have a mechanical pump going bad or some restriction somewhere. Also, possibly your tank or cap is not venting and it's taking the electric pump to pull it from the tank and push it to the engine. When opening your fuel filter do you notice any pressure being released?"
Sorry about the confusion, but yes it used to fine (except for the drop in fuel pressure, occurring only under load, and solved by kicking on the e-pump....never understood why that has always been that way) meaning running about 6 PSI. The increase to 9 PSI is a new problem and my concern. No, opening the fuel cap doesn't result in an audible sound.
I'll probably have to check the pressure using a fuel gauge but looking for other causes, than a bad gauge. thanx. s
steve meltzer
02-26-2017, 05:15 PM
And how are your two pumps plumbed? In series, in parallel? What size are your lines?
02-26-2017, 06:25 PM
Club Cobra Member
TX
The rear mounted e-pump feeds into the mechanical pump. I would call this series and I dunno the ID of the lines, but they're all original. They are braided; I can measure the OD when I'm next out there. They feed a fuel log/rail with dual feeds to the Holley.
steve meltzer
02-26-2017, 06:45 PM
Alright. No mechanical pump should be putting out 9psi. Your needle/seat valve in the 4160 bowls won't like that. Do a quick fuel pressure check right in front of the carb (with the electric pump OFF) and see if you really have 9psi or if your dash gauge is wrong. The goal will be to get a nice, even 6psi or so without having to switch on your electric pump.
02-26-2017, 07:44 PM
I second the mechanic fuel pump not putting out 9 psi. Gauge has got to be reading a little high. Holley high volume mechanicals shut off at 7.5-9psi. Me thinks you should bag the mechanical pump and go with the electric or vice versa. I can't imagine the need for a redundant fuel system like that in which you have to physically flip the switch to make the car run right. I'm sure it's possible and may be your case but I don't recall where I've ever read that a mechanical fuel pump failed on a Cobra, simply because they are not daily drivers and don't see that much action.
Maybe I'm missing something, anyone else out there have two fuel pumps?
I can see where one might run a second electric pump with a dedicated line from the tank to a fuel nitrous solenoid, but two pumps to a vacuum secondary carburetor for normal or spirited driving seems like a lot of ambition.
Simplify
02-26-2017, 09:12 PM
Club Cobra Member
TX
Probably won't get to this for a week or so, but will post the data. thanx so much. All of this makes sense to me. thanx again. s
steve meltzer
02-27-2017, 10:24 AM
OK, so we have:
Perfectly normal; as it should be.
Hmmmmm, maybe the mechanical pump is collapsing the rubber fuel line coming in to it, thus causing the output pressure to drop to 2 to 3. Then when you switch the electric pump on it opens the collapsed rubber line back up and the pressure is restored. That would do it... and it would be a damn tricky gremlin to find.
... and now
Either the gauge is wrong or the mechanical pump is now broken. If you have a little Go-Pro camera, it would be interesting to see if the rubber supply line, either right by the fuel pump or maybe back at the tank itself, is collapsing on load when the electric pump is off. But, regardless, we'll figure it out. There's not that many things it could be.
02-27-2017, 04:31 PM
Club Cobra Member
TX
Yep Patrick, you got it perfectly. I'll get to check the pressure ASAP, but I don't have the GoPro, tho' i do know what it is! If it's the mechanical pump, maybe I just put a plate over it and run the line to the fuel rail. Do they make sucha plate so I can just ditch the mechanical pump....tho' it's nice insurance should the e-pump fail. thanx again. more later. s
steve meltzer
02-27-2017, 04:41 PM
Sure - it's just a block off plate. Like this: https://www.summitracing.com/parts/p...view/make/ford but the next time you stroll through the garage, bend over and see if you pinch the black fuel hose going to the mechanical pump close with your fingers. If it feels "squishy," then it may be collapsing on you.
02-27-2017, 06:28 PM
IL
Cobra Make, Engine: Kirkham #259
And maybe the filter inside the electric fuel pump is partially dirty and restricting the flow of fuel to the mech pump....then when the electric pump is activated, it forces enough fuel to the mech pump to provide enough fuel for the engine.....
I'm just saying ...gremlins do exist with a 15 year old pump...
Morris
02-27-2017, 06:38 PM
Maybe. But Steve says it's "Been that way forever..." -- and I can see the installer reaching for a worn out piece of hose when he dropped the engine in.  It held up long enough for him to get it out of his shop. But, it's sure easy to just bypass the electric pump fuel lines for quick test up to 3K. Of course, he still has that pesky 9psi coming out of the mechanical pump. Unless his gauge is wrong.
02-28-2017, 05:10 AM
AR
Patrick brings up a good point about any rubber line feeding into the mechanical pump could be damaged from Ethanol and collapsing under suction while the electrical pump pressurizes it and forces it open. Something still wrong with the 9 PSI however.
Yes, feeding a mech pump with an electric one is not unusual. I've had that arrangement on a Corvette for 25 years now. You can use the electric to prime the carb before starting if the car has been sitting a while.
02-28-2017, 06:54 AM
Club Cobra Member
TX
I've got to square that (a collapsed hose) with the fact that it's been this way from day 1 (and I'm the original owner). When I turn the car to the "on" position, before the 9 PSI fiasco, the initial fuel pressure reading was 3 PSI (regardless of how long the car had been sitting). I too, always kick on the e-pump and watch the gauge until I have 6 PSI, then start the car. Thanx for hours of entertainment here...i'm learning a lot and appreciate the schoolin' s
steve meltzer
02-28-2017, 08:07 AM
OK, let me be clear on this. Are you saying that when you go out to your car, say in the morning after the car has not been running, and you turn the key and electric pump switch on, but do not start the car, that you hear the whir of the electric pump and that it only goes up to 2 or 3 psi, even after waiting, say, 15 seconds? Or are you saying that it initially starts out at 2 or 3 psi and then, after a few seconds, goes to 6psi and then holds there? The first is abnormal, the second is perfectly normal.
02-28-2017, 09:55 AM
Club Cobra Member
TX
With the key in the on position (not start) and e-pump off, my initial pressure is 3 PSI, but then, after engaging the e-pump, the pressure goes to 6PSI, as it should. This was the case BEFORE I started seeing pressures of 9PSI. (so the latter of your two possibilities) steve
steve meltzer
02-28-2017, 10:26 AM
OK, that's good. By the way, over the last 15 years have you ever had to pull the fuel bowls off for any reason? And were the floats ever adjusted, or just left at the factory setting?
03-03-2017, 04:13 AM
AR
Steve - what type of fuel tank do you have? Is it one of those bladder style tanks or a fuel cell with foam? Kind of sounds like something restricting flow from the tank.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
