Old 07-06-2014, 02:51 PM
philminotti's Avatar
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
Default Refreshing a brushed finish
Once upon a time, there was a procedure for rejuvenating a brushed finish, but i can't find it anymore. In the process of dropping my motor in and doing all the wiring, the car had taken a bit of a beating. Does anyone have a good sequence of grits and materials for redoing the brushed finish?
Old 07-06-2014, 05:27 PM
I'd call the Kirkhams and ask.
Chas.
Old 07-06-2014, 05:35 PM
Uhhh, didn't it involve Windex and elbow grease?
Old 07-06-2014, 05:50 PM
Or you could test in a hidden area with this:
Car Cleaning Products | Glass Cleaner | Bar Keepers Friend
Chas.
Old 07-06-2014, 06:17 PM
rodneym's Avatar
Full Blown Member
Premier Contributor
I think philminotti means more than a clean.
I'd definately give the K's a call.
I believe it involves a course round of sandpaper, like 120 grit or so.
The brush scratches very easy, so it would need a refresher every few years if you want it to look that way.
I simply correct areas with the red 3M scuffer. After a while, it dulls and blends ok.
BIG job to do the whole car, though.
rodneym
Old 07-06-2014, 06:21 PM
RodKnock's Avatar
I'm assuming it doesn't need to be cleaned, but here's what Kirkham recommended at one point:
www.clubcobra.com/forums/1158207-post7.html
Does it require any skill? Or can you just hire five or six guys from the corner in front of the 7-11?
Old 07-06-2014, 06:26 PM
They will make your KMP DISAPPEAR-along with every TV in the house...
Chas.
Old 07-06-2014, 06:38 PM
Thanks. That's exactly what i was looking for.
Old 07-07-2014, 09:29 AM
Cobra Make, Engine: Kirkham 599 Polished Bronze
May sound crazy, but I've used a good paste wax to make the car easier to clean. I go with the grain of the sanding. Dirt and road grime come off easily. Mine is brushed aluminum.
Old 08-18-2014, 05:36 PM
Avmaviator's Avatar
Cobra Make, Engine: Kirkham #647 brushed
Rebrushing the car is pretty easy. I got a few red 3M pads at the local hardware store and just brush it in the direction of brushing, front to back. Is that what you are asking? Pretty simple job really…
Old 08-19-2014, 07:24 AM
Avmaviator's Avatar
Double post
Old 12-24-2014, 09:52 PM
David Kirkham's Avatar
Original Shelby Owner
Wax works pretty well to protect the finish.
David
