questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
07-06-2014, 02:51 PM
CT
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
Refreshing a brushed finish
Once upon a time, there was a procedure for rejuvenating a brushed finish, but i can't find it anymore. In the process of dropping my motor in and doing all the wiring, the car had taken a bit of a beating. Does anyone have a good sequence of grits and materials for redoing the brushed finish?
Advertising
07-06-2014, 05:27 PM
I'd call the Kirkhams and ask.
Chas.
07-06-2014, 05:35 PM
Uhhh, didn't it involve Windex and elbow grease?
07-06-2014, 05:50 PM
Chas.
07-06-2014, 06:17 PM
Full Blown Member
I think philminotti means more than a clean.
I'd definately give the K's a call.
I believe it involves a course round of sandpaper, like 120 grit or so.
The brush scratches very easy, so it would need a refresher every few years if you want it to look that way.
I simply correct areas with the red 3M scuffer. After a while, it dulls and blends ok.
BIG job to do the whole car, though.
rodneym
07-06-2014, 06:21 PM
I'm assuming it doesn't need to be cleaned, but here's what Kirkham recommended at one point:
www.clubcobra.com/forums/1158207-post7.html
Does it require any skill? Or can you just hire five or six guys from the corner in front of the 7-11?
07-06-2014, 06:26 PM
  They will make your KMP DISAPPEAR-along with every TV in the house...
Chas.
07-06-2014, 06:38 PM
CT
Originally Posted by RodKnock
Thanks. That's exactly what i was looking for.
07-07-2014, 09:29 AM
TX
Cobra Make, Engine: Kirkham 599 Polished Bronze
May sound crazy, but I've used a good paste wax to make the car easier to clean. I go with the grain of the sanding. Dirt and road grime come off easily. Mine is brushed aluminum.
08-18-2014, 05:36 PM
IL
Cobra Make, Engine: Kirkham #647 brushed
Rebrushing the car is pretty easy. I got a few red 3M pads at the local hardware store and just brush it in the direction of brushing, front to back. Is that what you are asking? Pretty simple job really…
08-19-2014, 07:24 AM
IL
Double post
12-24-2014, 09:52 PM
Ut
Wax works pretty well to protect the finish.
David
