questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
04-24-2007, 06:14 PM
Banned
Kirkham Roller to Completion
How long did it take you to get you Kirkham (for those of you who got a roller) from the day you got it to completion?
Advertising
04-24-2007, 06:22 PM
SC
13 months or so
04-24-2007, 06:39 PM
Mo.
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Wow!!
ENTDOC, were you restricted to weekends or is that a realistic time frame? Over a year seems like a long time, any hangups with parts delivery or otherwise?
04-24-2007, 07:45 PM
OH
Cobra Make, Engine: Kirkham 427FE (sold & missed)
bought mine used.........I needed instant gratification.............
Brian Newell - Superformance Sales
Mansfield Motor Group
www.mmgauto.com
04-24-2007, 08:47 PM
ca
Cobra Make, Engine: Kirkham #185, Shelby Alloy 482; sold
Me too. Had the $ and not the skills.
Dave
04-25-2007, 04:02 AM
VA
Cobra Make, Engine: Kirkham 427 & 289 (KMP 090 & KMPS 040) and need a Kirkham GT-40
Seven years and still waiting for the kirkham fairies to come in the night. I suffer from a severe case of Car A.D.D.. You're lucky I even finished this posting. See ya', off to another website. BERT
04-25-2007, 05:56 AM
fl
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
November until now to do two
I just finished two (except for alignment on one of them). Weekends and a late night here and there. KMP 473 and 474. Hope you have a car lift.
04-25-2007, 06:09 AM
Banned
So, how long?
04-25-2007, 09:50 AM
CA
Cobra Make, Engine: KMP 498
I have one-just got it. Roller, if you have your engine & trans and diff ready to put in and you don't have to fabricate your sidepipes or something crazy like that- you could litteraly do it in a weekend. Wires are already there just hook up and go. I turned the battery swith on and I can even turn on the fuel pump. Thes guys really have figured it all out. Now sanding/ painting, parts assembly would be more of coarse. I hope to be on the road by end of summer. I rub on it alot.
04-25-2007, 10:33 AM
Stolen Avitar
GA
I do that as well, but I fail to see how that will get your car finished any more quickly!
BaaaaaHaaaaa!!!!!!!!!!  (couldn't help it)
Steve
04-25-2007, 10:42 AM
KY
Rob, it's a custom built car. Don't pull the same crap that you did with SPF and Performance Engineering. Seriously...if you're that impatient, buy something else. And again, if you're gonna be that anal about things going wrong, then buy something else.
04-25-2007, 10:50 AM
CA
I had to build mine up to "roller" status and even with that included it was only about 200 hours total.
If money isn't slowing you down, I can't imagine going from roller to done would be more than 70 or 80 hours worth of work unless you are so anal that you couldn't pull a needle out of your butt with a tow truck.
04-25-2007, 10:53 AM
fl
A solid two to three weeks
If you have the tools and parts ready to go you could do it quick. I spent more time than I should have because of work travel away from home. You have to have a lift, a welder and hand tools.
04-25-2007, 10:57 AM
Mo.
Murphy,
What aspects of your builds did you need the lift and welder for?
04-25-2007, 11:13 AM
fl
Tools
You need a small mig welder to weld the brackets and tabs on the sidepipes. You have to fit the pipes to the car and motor, then weld. You can buy one for $100. You will regret not having a lift for the under car work. Of course it can be done but what a pain in the A$$. The home lifts are under 2K and well worth it. You can put it together in a weekend no problem.
04-25-2007, 11:24 AM
ca
Cobra Make, Engine: owned Kirkham for 11 years
30 days after the Keith Craft engine and Tremec arrived,We had it on the road. Biggest expense was the welding done by an on site vendor.
Maurice
04-25-2007, 11:32 AM
IL
Cobra Make, Engine: 427 Cobra re-creation based on Kirkham aluminum body and chassis, Original 1965 Ford 427 Side Oiler and Ford Toploader transmission
About 10 months but my timeframe is a bit invalid since I went backwards first after receiving the roller. The roller was completely disassembled, painted and then built as a ground up restoration from that point.
04-25-2007, 11:36 AM
SC
bought mine on a whim and my first cobra was not even on the road yet, so KMP266 sat for quite a while so I could finish the other one. After it got started it was done in 2 months or so.
| Thread Tools |
| Display Modes |
Linear Mode
