October 2025
26 27 28 29 30 31
  #121 (permalink)
Old 11-16-2010, 10:06 AM
Dominik's Avatar
Default upper suspension mounting holes 1.5"
Hi David!
Please explain why the upper suspension (front and rear) have big holes with 1,5" diameter to accept cups to sink the 5/8" bolts. Is that for radiator clearance (front) and main tub clearance (rear)?
Meaning it's a package problem, design error?
Dom
  #122 (permalink)
Old 11-16-2010, 02:01 PM
David Kirkham's Avatar
Original Shelby Owner
Originally Posted by Dominik View Post
Hi David!
Dom
That is how the original suspension was made. In our latest chassis we have a 5/8" hole.
  #123 (permalink)
Old 11-16-2010, 09:49 PM
Dominik's Avatar
My buddy Nick says it a safety feature, to collapse in a crash.
I came in late for the build manual and I face a similar challenge as when I tried to follow Morris C's build up in gasholes.
It's tricky to find a specific step or a picture. In my case:
Where is the transmission crossmember pic which shows mounts for Toploader and Tremec?
A table of content would be good, but impractical because you build and documents as you go along, not according to a pre-defined table of content.
Anybody has any ideas how to find a specific topic a few pages back?
Maybe do create a table of content on the first page which "lives" as you go along?
Dom, Cape Town
  #124 (permalink)
Old 11-22-2010, 04:10 PM
Cobra Make, Engine: KMP 498
Default Clutch Adjustment?
Quicktime Bellhousing- Kirkham Cool linkage setup:
Start me from scratch- How far should the bolt on the BH be adjust? How do I adj it in the first place? I do not think I am getting enough throw.
Sanded Aluminum Finish? Because I Can!
  #125 (permalink)
Old 11-22-2010, 05:02 PM
I am not sure what bolt on the bell housing you are referring to.
What size master cylinder are you using? Are you using our set up?
  #126 (permalink)
Old 11-28-2010, 04:06 PM
I am using your complete set up. The pivot point bolt- heim joint. Looks like in the pictures I have more showing- at about 3/8 in. seems like you guys only have a thread or so. I originally set it up so the fork was perpendicular to the centerline of trans.
  #127 (permalink)
Old 11-28-2010, 04:11 PM
We screw the rod end out all the way so only a 1/2 a thread shows. That puts the pivot point in the right place.
  #128 (permalink)
Old 12-01-2010, 05:30 PM
Thanks- On it!
