Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Midstates Cobra's---Speak with Bob Kallio
Old 08-21-2007, 08:25 PM
RedSabre's Avatar
Registered User
Cobra Make, Engine: Midstates
Default How did you mount your rear license plate?
Need some advice on how everyone is installing their rear license plate. Reason is the Texas plate will not fit between the license lamp fixture and the trunk handle. We ended up mounting it on the bumper rails and really don't like it. It appears Midstates did not take this into consideration when designing the spacing. Any suggestions from fellow Midstates owners?
Old 08-21-2007, 09:04 PM
Dwight's Avatar
Smile Tag bracket
I don't have a Midstate but I have made stainless tag bracket for a few of our Cobras. Mine is a Lone Star and I made one for Mike's FFR and Hurricane. I use angle and/ or flat stock. Weld up what we need and polish till it shines like chrome.
Never had one of these to break and drop a tag.
Dwight
Old 08-21-2007, 09:36 PM
RON N BKFLD's Avatar
Cobra Make, Engine: KMP241 427 S/C 482 Shelby
Red......you have a message,,,,,,,,,,,,,,Ron
RON N BKFLD
Old 08-22-2007, 11:27 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
I just did a little trimming on the plate itself - got the idea from Bob's car...
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
Old 08-22-2007, 12:13 PM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
Mine is trimmed like ZIPZIP,s. It is not the Texas license plate, its the spacing between latch and light. See my gallery.
Old 08-22-2007, 12:45 PM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
The reason that the plate doesn't fit is because the original cobra is european and their plates are much narrower, most cobra replicas are keeping the original lookand therefore U.S. plates are to big to fit. Finishline sells a plate hanger that is angled out to clear the trunk handle.
http://www.finishlineaccessories.com...abb37134da27a5
Cobrarich
Old 08-22-2007, 01:04 PM
ItBites's Avatar
My midstates (built in 1992) is done just like zipzip. Bolts go through the trunk lid. Notched the plate to fit over the handle as shown in zipzip response. This is mor like the oroginals than the lonestar above where they have a large bulge, higher up on the lid.
just notch the plate and you'll be OK.
E. Wood
ItBites
Old 08-22-2007, 07:53 PM
RedSabre's Avatar
Registered User
I knew you guys would recommend the trimming solution which I did think real hard about already. We were hoping someone had figured out another clever way. Never know, we do have some clever folks out there.
Thanks to all for your suggestions. Really like your bracket, Dwight. Really sharp design. Well we will be thinking about this some more as we would really like to get this plate off the bumper rail.
Old 08-22-2007, 08:45 PM
GlynMeek's Avatar
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
Mike...shave the trunk...makes the problem disappear...
Regards
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
Old 08-23-2007, 08:19 AM
sharpe 1's Avatar
Finishline offers a bracket that may help.
Old 08-23-2007, 08:42 AM
CHANMADD's Avatar
I trimmed mine top and bottom.
Old 08-23-2007, 09:38 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Mine is off to the left. I didn't like it under the trunk handle.
Old 08-23-2007, 10:48 AM
Dwight's Avatar
Smile Tags
Glyn
What type of fiberglass did you use to rework the tail light area?
I took a better picture of the tag bracket today.
Dwight
Old 09-18-2007, 07:12 AM
Cobra Make, Engine: MidStates, 351W
I took the handle off the trunk, drilled a hole in the plate and mounted the handle throught the plate.
Old 09-18-2007, 08:56 PM
GlynMeek's Avatar
Dwight...just regular old fiberglass sheet and resin. Cut away ALL the light area and then laid down multiple layers from the inside until it was all done, then sanded inside and outside and smoothed with 'bondo' filler.
Of course, you have to add a 'hidden' trunk pull then to open the trunk!
Glyn
