Like Tree1Likes
  • 1 Post By Tommy
Old 08-13-2012, 06:06 AM
S1013's Avatar
Cobra Make, Engine: ERA #3002 Slabside
Default 289 vs 427 Side Emblems
I am in the bodywork phase of an ERA slabside. While the exact measurements for mounting the side emblems for the 427 car is quite easy to locate, I am having problems determining exactly where to drill the holes for the 289. I do not have easy access to an original to measure. Looking at all the photos I can find it appears to be about 1/2 inch higher than the side vent and the back side about lines up with the hood handle. Greatly appreciated if anyone has some real measurements.
Old 08-13-2012, 08:07 AM
I've got the early mounting position from Doug's notes. I'll post a diagram today.
Old 08-13-2012, 08:59 AM
FatBoy's Avatar
I've used double side tape for the emblems so that I didn't have to drill holes.
Paul
Old 08-13-2012, 12:53 PM
I used Doug's notes and a little analysis from my photos of the original cars.
Side emblem placement
Old 08-13-2012, 01:40 PM
S1013's Avatar
Default Side Emblems
Excellent! Thank you. And when I drop them and break the pins off I will use
the double sided tape!
Old 08-13-2012, 05:27 PM
KarlCSX2498's Avatar
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
Default Powered By Ford Emblems, location
Hello, I checked on CSX2498 and from the top of the side vent it is 1" to the bottom of the emblem, from the door opening it is 12.5" to the back edge of the emblem.
Hope this helps, karl
Old 08-14-2012, 05:57 AM
S1013's Avatar
Default Emblem Location
Thanks Karl, I wouldn't be surprised if it moved slightly based the serial numbers. I found quite a few photograghs of "original" cars where it appears a bit different.
Old 08-15-2012, 01:27 AM
If you don't have louvers at all, where is it place then?
Old 08-17-2012, 06:29 PM
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
My measurements agree with Karl's except I have 7/8" from top of louver opening to horizontal line along bottom of emblem,although since the louver isn't exactly level we are awful close.
Old 01-29-2014, 06:45 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Hey guys, I'm working on the Owner's Manuals for the MKII Street & FIA from Superformance and will probably review what is said here and compare it to the information I have collected so far on badging The info will appear in the service bulletins for both for the MKII chassis. Thus far from the discrepancies in the measurements I see posted and the info I have, I thinking that most of the badges were eye-balled when installed at the factory. Seems to be +\- 0.25" on badge placement. But I'm guessing the bodies themselves has the same +\- tolerances.
SPFWiringDiagrams@Comcast.net
Old 01-29-2014, 07:03 PM
Senile Club Cobra Member
Well as CS said, the "winos under the bridge" probably had a plus/minus of three feet!
rick@autoventureusa.net
Old 01-30-2014, 01:11 AM
rsk289's Avatar
Knowing the British low-volume car industry of the sixties pretty well, I'd be very surprised if the originals had them all in the same place...
Old 01-30-2014, 05:23 AM
Tommy's Avatar
This conversation reminds me of an old saying I learned in engineering school (also in the 1960's). "Measure with a micrometer. Mark with chalk. Cut with an axe." I took the point to be that sometimes accurate measurements are not required.
db replicas likes this.
Tommy
Previously owned EM Cobra
Old 01-30-2014, 07:35 AM
1985 CCX's Avatar
I looked at several original cars to determine the location. Even more dicey when there is no vent.........
There is a bit of averaging with measurements.........
Ballpark, estimate and drill.............
Old 01-30-2014, 03:04 PM
mickmate's Avatar
Bob and Karl have you covered
mickmate
http://www.actoncustom.com/
Old 01-30-2014, 04:41 PM
Cobra Make, Engine: Superformance 427R
Hey Mickmate, that picture would be really handy on the thread about parking brake location.
Old 01-30-2014, 04:49 PM
mickmate's Avatar
mickmate
