Old 01-14-2013, 07:37 AM
Default capillary -> firewall routing
Its that time now where I finally need to drill the firewall for the capillary tube grommets - I have Smiths mechanical gauges.
The crendon has a removable centre section on the firewall, so I may drill the holes to the side above the footwells so this panel remains removeable, if needed in the future.
But before I drill, I though i'd check where other people had routed these, where the holes had been placed, and any top tips.
any suggestions and comment much appreciated.
Crendon 427, in the making
http://crendonreplicas.com/
Old 01-14-2013, 10:19 AM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
Rather than drilling such a large hole through the firewall to accomodate the capillary tube, I ran it along the right frame and up the side of the footbox at the front of the tranny tunnel. I then drilled the top of the tranny tunnel into the passenger compartment behind the dash. I ran several wires through this same opening and fabbed an alum channel to conceal them running up the side of the footbox/tranney tunnel. Looks very clean.
Can post a pic later if you're interested.
Matt
Hurricane Motorsports #1053; 427w
Old 01-20-2013, 01:35 PM
.... interesting - be great to see some pics of thos - thanks!
Old 01-20-2013, 04:44 PM
Cobra Make, Engine: SPF #298 427 FI
I have one on each side. Just high enough to run under the dash.
