Old 01-20-2013, 11:25 PM
Default USRRC oil pressure gauge question
For the experts on originality:
From photos I have seen, the normal SW oil pressure gauge for the 289 street cars was the 90 degree sweep version (during the SW era). It appears that the USRRC cars like 2 4 5 8 and 2 4 5 9, and maybe 2 5 1 4 came with the street dash w/glovebox. I have some photos of 2 4 5 9 that show a 270 degree sweep oil pressure gauge. I was curious to know if that gauge would have been the 0-80lb or the 0-100lb version... can't make it out on the photo. Was there any consistancy? Would it being a race version mean they used the higher range gauge, or the 80lb gauge like the street version? It is the smaller size 2-1/16" gauge, rather than the 2-5/8" race gauge.
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 01-21-2013, 04:34 AM
1ntCobra's Avatar
Abnormal CC Member
CSX2514
Old 01-21-2013, 04:44 AM
1ntCobra's Avatar
Abnormal CC Member
CSX2431
Old 01-21-2013, 08:21 AM
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
The picture of 2514 above gives the answer. Usrrc cars no consistency .See fuel pressure gauge is a 2 5/8th gauge, probaly one that was in stock. The rest normal street 2 1/16th.
Ross
Old 01-21-2013, 10:14 AM
Rick Parker's Avatar
On CSX 2514, the gas cap has some sort of addition. Is this a vent or ???
Old 01-21-2013, 10:56 AM
1ntCobra's Avatar
Abnormal CC Member
The extra thing is on the gas cap of CSX2431. I think it is like a washer welded on top of a screw.
Maybe you could wrap a rubber band around that and the latch to make the latch close tigher?
Old 01-21-2013, 12:10 PM
Dan Case's Avatar
Original Shelby Owner
Look at enough old publications and you'll see team cars with a long loop pad lock on the fuel caps at some time or another.
Dan Case
Old 01-21-2013, 12:15 PM
Dan Case's Avatar
My home grown solution after my first open track was to cut a couple of short pieces of heater hose, slit one side lengthwise, and slip it over the boot lid frame tube work. There is no interfence with opening and closing the boot lid but it would no longer rattle and shift side to side so much it could come open. Added no holes or other permanent changes.
Dan Case
Old 01-21-2013, 02:39 PM
"Look at enough old publications and you'll see most of the team cars with a long loop pad lock on the fuel caps at some time or another." Was that to stop the pesky Chevvy boys from sabotaging the gas, Dan ?/
Joking aside, this is the first reference to that, that I`ve heard, but have seen what I think Dan is referring to on a coupe. Difficult to be sure but one can just make out the loop of the lock. Any references or pics? as I find this sort of thing intriguing.
Old 01-21-2013, 02:50 PM
Dan Case's Avatar
No specific references come to mind but I have a fair collection of old magazines. Somebody did a list once and Cobras were covered in some way in something like 300+ publications 1962-67. The team lost at least one major race after somebody loaded the fuel tank with what was described as just dirt. I believe they showed a picture of the clogged filter element that was pulled out. I bought a 1967 GT500 once that wouldn't run long. Ran fine then quit. I pulled the fuel tank and dumped it out into a tub. There was literally a large soggy handful of flowers and grass clippings in the tank.
Dan Case
Old 01-21-2013, 03:00 PM
1ntCobra's Avatar
Abnormal CC Member
I remember reading that one of the FIA cars in Europe had stopped running during a race and it appeared the fuel system was clogged with a cloth like material.
Old 01-21-2013, 03:17 PM
That was Hill at Spa 1964 in a coupe.
Old 01-23-2013, 11:16 PM
Ross
Getting back on topic, actually, the 2-5/8" fuel pressure gauge is quite common on the USRRC cars and others, even though it didn't match the smaller street gauges. There was one on 2 4 5 9, as well.
It appears that the oil pressure gauge in the photo of 2514 is the 0-80lb gauge. Again, anyone in the know on the correct range for the oil pressure gauges in the USRRC cars?
Paul
Old 01-25-2013, 07:21 PM
Thumbs up
CSX2514
I have to admit... that oil pressure gauge sure does look the part of an original, with the yellowed face printing! Thanks for posting this.
Paul
