November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-25-2013, 03:12 PM
Club Cobra Member
Cobra Make, Engine: NAF 427
Default Cobra 427 Street: Hood latch locations
Hi all. Can anyone give me the the hood latch location measurements for a 427 Street roadster?
Distance apart center to center
and
Distance back from the edge of the hood.
I'm trying to figure out if I can relocate the hood latches on my NAF. The configuration of the stiffner/lining of my hood may not allow it, but I'd like to try.
Thanks
Greg
Old 11-25-2013, 03:50 PM
mickmate's Avatar
Hey Greg,do you have a rib in the inner skin or a frame to work around?
mickmate
http://www.actoncustom.com/
Old 11-26-2013, 09:51 AM
Club Cobra Member
Hi mickmate. Yes I do have to workaround stiffening ribs on the bottom side of the hood. Post pics later.
Another thing came to mind. Did the Street 427 Cobras use long or short cams on the latches?
Greg
Old 11-26-2013, 01:31 PM
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
My original street car is 25&7/8 inches center to center measuring along the crown. 2.5 inches to the center from the edge. I don't know if it's a long or short cam since I don't know what the difference is.
Old 11-26-2013, 02:14 PM
Club Cobra Member
I think I have attached a picture of the cam on my car with a quarter to give an idea how long the cam is. Hope this helps.
Old 11-26-2013, 02:21 PM
Club Cobra Member
Second try to attach photo on cam length.
Old 11-26-2013, 06:01 PM
Mickmate, I sent you a PM, thanks..
Old 11-26-2013, 07:02 PM
mickmate's Avatar
I measured around 2-5/8" from the edge of a couple and fairly consistent with the 25-7/8". Dimensions like this vary a lot from car to car by 1/4" or more on these handmade cars. They don't use a cam they use a latch plate as shown.
mickmate
Old 11-27-2013, 08:04 AM
Club Cobra Member
Thanks for all the info and pics guys. I think I have enough now to figure out how to go from here.
Mickmate: do you know if latchplates are available anywhere?
Greg
Old 11-27-2013, 09:19 AM
mickmate's Avatar
Hood Catch
I have some more original spacing available. I could put a package together for you.
mickmate
Old 11-27-2013, 09:51 AM
Club Cobra Member
Thanks mickmate. I'll check it out and PM you.
Greg
Old 11-27-2013, 11:26 AM
Tony Ripepi's Avatar
Cobra Make, Engine: TBD
Talk to the folks at Finishline and in my pics there is an old side by side comparison of the original street car to the Comp SC.....lots of pics etc.
Tony R.
Old 11-27-2013, 11:49 AM
Club Cobra Member
Thanks Tony. Great pics.
Greg
Old 11-27-2013, 11:50 AM
Hello All,
If you want to review the entire article I mentioned from 1965 go to the ERA web site.
Sports Car Graphic, November 1965, Double Cobra test
I do have the original magazine at home.
Tony R.
Old 11-27-2013, 04:57 PM
frdfver's Avatar
Cobra Make, Engine: N.A.F., 351 cleveland, 9" ford
Greg, What I did on my NAF was ordered some originals, then tore them apart for the springs and catch. Measured how long the latch had to be to reach and cut one out that long, then cut some metal out the shape of the originals long enough for the new latch and bent them up. So I ended up with some supersized versions of the original latches. Just need to cut the shafts for the springs and pins.
Images in my gallery if insert doesn't work.
Paul T.
Old 11-28-2013, 10:03 AM
Club Cobra Member
Thanks Paul. Great job. I think I will follow a similar path. But I have cut out the curved corner gusset on the body, so I will relocate my latch so it will contact a "receiver" fastened to the firewall.
Send you the manual after the black friday madness.
Greg
Old 11-28-2013, 11:42 AM
frdfver's Avatar
Should turn out good and look closer to an original. Forgot to say that mine turned out 24in. apart and 4in. from the edge of the hood. Looking forward to browsing thru the manual.
Paul T.
