Like Tree9Likes
  #21 (permalink)
Old 03-26-2014, 04:04 PM
Ralphy's Avatar
xb-60, you may have taught me something. I was thinking mild steel such as 1020 contained no more than 0.2% carbon? Being the second two digits represents the carbon quantity. Same in all steels a high carbon of 1040 equaling no more than 0.4%?
Ralphy
What?
  #22 (permalink)
Old 03-26-2014, 04:24 PM
joyridin''s Avatar
Originally Posted by ItBites View Post
Joyridin: My theory is based upon over 24 years of building rockets for NASA, the DOD, the MDA and commercial industry. The latest is a small vehicle called Antares - goes to the space station sometimes. And no, this device is not used by us, our suppliers, or our customers since it is not a Mil Spec allowed technique. At 3% accuracy, a user may think the composition is accurate, and an answer is produced, but the answer may well be wrong. The sellers do state on their website that this is used in Aerospace though, and we all know it has to be true because its on the internet. I have confidence you are using this device within its intended parameters and wish you the best, but I have looked at the specs and again wouldn't (and don't) base million dollar decisions on it.
You have never seen the item, don't know how it works, and never used it, but you are going to sit here and argue its merits and what it will and won't do.
Yeah....discussion is over on this item. You can't argue with ignorance.
Ralphy likes this.
  #23 (permalink)
Old 03-26-2014, 04:52 PM
ItBites's Avatar
Cobra Make, Engine: Midstates, Vette suspension, Baer 6P brakes, 540 cid Chevy, Haltech Fuel Injection
Joyridin, I don't have to use this to research it and its uses, just like I don't have to use crack to understand it is a bad drug. I have performed the required research and have verified it does not meet the Mil Spec criteria for determining material composition and is therefore not usable for my applications. Check it out for yourself and tell me I am wrong in this statement. I do this sort of thing all day long, yawn...
I wish you the best in your endeavours and, as said before, I am certain you are using this device within its intended parameters and hope it provides you with many years of profitable service.
E. Wood
ItBites
10.69 @ 129.83mph - on pump gas and street tires
  #24 (permalink)
Old 03-26-2014, 04:56 PM
blown871's Avatar
Cobra Make, Engine: SPF
Kryptonite; off limits for me personally.
Ralphy likes this.
  #25 (permalink)
Old 03-26-2014, 05:22 PM
Ralphy's Avatar
[ame=http://www.youtube.com/watch?v=wcW_Ygs6hm0]Major Kong Rides the Bomb - YouTube[/ame]
Ralphy
Bill D and xb-60 like this.
What?
  #26 (permalink)
Old 03-26-2014, 06:12 PM
... I have performed the required research and have verified it does not meet the Mil Spec criteria for determining material composition and is therefore not usable for my applications ...
That's where the disconnect is, Mil Spec criteria is NA for this application of determining metal composition ... we don't shoot '65 cobras into space. Obviously a portable metal spectrometer has a "market" or they wouldn't make it, and perfectly suitable for the purposes discussed here (probably more accurate than the spec sheet coming from the raw stock metal supplier in '65). For a guy that's been in the aerospace biz for 24 years, you ought to know ground support equipment comes from suppliers typically following best commercial practices with an acceptable QMS, Mil Spec requirements have no place here.
joyridin' and Ralphy like this.
  #27 (permalink)
Old 03-26-2014, 10:46 PM
xb-60's Avatar
Ralphy
Ralphy,
My figures were for CA2S-E (cold rolled, formable) http://www.bluescopesteel.com.au/files/CA2S-E.pdf
which is similar to 1010, and has a max carbon content of 0.10%
You're correct that 1020 has a maximum carbon content of 0.20%
Glen
  #28 (permalink)
Old 03-27-2014, 10:10 AM
ItBites's Avatar
Al and others: I get the point about this application might not need to be particularly accurate. You may be correct. I'll top that by suggesting that AC would have been unlikely to specify anything other than 'mild steel' and probably got materials over the years from various suppliers , which would make determining authenticity by comparing to sibling materials very dicey, even with the highest accuracy equipment and techniques.
Also, since you brought it up, most GSE is not even allowed to be built to industry practices due to the sensitivity of lifting, handling, interfacing, or pressurizing one-of-a-kind, high-value hardware. the downside of a COTS GSE component failure is just too catastrophic in terms of human and financial loss (think of dropping a large rocket motor). There are some exceptions to this of course, but most GSE just defaults to being Mil Spec compliant. You have no idea what it takes to get NASA (and customers in general), the Ranges (who let us integrate on their proerty and let us fly out), the FAA(who controls the airspace), the DOT (who allows us to ship over the nations hiways), DCMA (who lets me handle and test ordnance), the DOD, and a myriad of others who poke their noses in my business to all agree that things are kosher. Most times it is just best to be able to point to a Mil Spec in order to stop the incessant do-loops that cost even more to navigate than complying with Mil Specs. Commercial Programs may be a target of opportunity for industry common practices and are assessed on a case-by-case basis, but that doesn't fly at all on DOD Programs, even for GSE.
E. Wood
ItBites
  #29 (permalink)
Old 03-27-2014, 02:11 PM
Ralphy's Avatar
Originally Posted by xb-60 View Post
Ralphy,
Glen
I never saw a material..... well I never cut a material with that low of carbon. We used to get a material called leadloy. You could fly thru the stuff. I believe leaded metals are gone. That must be nice for forming.
Added:
Maybe it's still available, it was 12L14 and called ledloy not leadloy.
Ralphy
What?
  #30 (permalink)
Old 03-27-2014, 02:32 PM
xb-60's Avatar
Ledloy is still a low carbon steel with carbon content at 0.15%, but it has 0.15 to 0.35% lead content which makes it a very easy machining and ductile steel
Glen
  #31 (permalink)
Old 03-27-2014, 03:51 PM
joyridin''s Avatar
I still have a lot of customers machining 12L14. I still have one machining 41L40. I have no idea where they actually buy the 41L40.
  #32 (permalink)
Old 03-27-2014, 07:27 PM
Slick61's Avatar
Cobra Make, Engine: BDR #89, KCR aluminum 427 windsor
portable x-ray analyzers can be had for much less that $20k. If you have a sample of the tubing, grind an area down to bare metal, clean it, then take it to a scrap yard that buys/recycles metal... they should have one. (they can also probably be rented, tho it would be pricey) Altho I don't know that I'd rely upon the results with respect to carbon content (which is the primary alloying element in a plain carbon steel). Ideally, carbon content is best analyzed via combustion. A 1020 plain carbon steel is, in general, pretty similar to an ASTM A36 steel... which would have a minimum yield strength of 36 ksi, and an ultimate tensile strength of 58-80 ksi. The requirements for a plain carbon steel are so loosely defined that a beer can would meet it. Having tensiles pulled would be more involved... and more costly... and definitely destructive. An alternative would be hardness testing with a portable, rebound-type hardness tester. The hardness-to-tensile strength correlation is pretty good for carbon steels. A commercial testing lab could probably get you chemistry & tensile/hardness for $300 or so.
R. Smith
Santa Clarita, CA
BDR #89- KCR aluminum 427 windsor, TKO-600
  #33 (permalink)
Old 04-01-2014, 01:38 PM
Uuups I opened the Pandora's box.
Plase no more fighting about devices and stuff - I was just interested if the steel from the Frame -. as being the "heart" of a car could be evaluated as genuine if we test this material.
I do still believe it would be an interesting add-on to proof the originality of a car. (Besides other indications of course) But with all these engines exhanged in period and later, all the re-worked interiors, all the custom made parts, all the interchangabel components and finally all the repaired/rebuilt bodies - there is not really a lot which is really genuine. Right?
So how to do figure this out? There must be a reason, otherwise folks like Ferrari Classiche and Mercedes Benz Historic Centre wouldn't do it as well?!
So what is the magical formula of genuine Cobra-frame steel???
  #34 (permalink)
Old 04-01-2014, 03:30 PM
xb-60's Avatar
What about doing a DNA test on the steel chassis?
Glen
  #35 (permalink)
Old 04-01-2014, 05:12 PM
aks801's Avatar
Cobra Make, Engine: None yet!
Send a message via Yahoo to aks801
Originally Posted by AL427SBF View Post
...we don't shoot '65 cobras into space...
And we have an early contender for 2014 forum quote of the year!
Ralphy and Ghiblicup like this.
Alan in Katy, TX
  #36 (permalink)
Old 04-02-2014, 07:35 AM
... most GSE is not even allowed to be built to industry practices due to the sensitivity of lifting, handling, interfacing, or pressurizing one-of-a-kind, high-value hardware ...
GSE is allowed to be built to industry/best commercial practices as long as the right checks & balances are there. You kind of forgot about the proof load cert with RFU tag (for lift, MEOP etc) but that's ok. You also forgot about the approved suppliers list where current ISO 9001 or AS9100 registration is a DoD requirement, but that's ok too. Bottom line, DoD can't move to COTS fast enough to get under the ISO/AS9100 umbrella and ditch outdated Mil Specs altogether.
  #37 (permalink)
Old 04-02-2014, 08:06 AM
Slick61's Avatar
not fighting... just trying to help.
call Shelby American... they may have an idea... tho who knows how many suppliers they bought their steel from over the years.
which brings me to a question... did the "original" Shelby 427 Cobras use a modified AC chassis, or was it a completely new chassis mfd by Shelby?
... but there may not BE a magical formula...
steels made today CAN BE much cleaner than those of 50 years ago, and most likely have more consistent/reproducible mechanical & microstructural properties... so as far as formula/composition... you could probably argue that the crappier it is, the older/more authentic it probably is. (tough to prove tho) Domestically made steel was, for many years, considered superior to that produced overseas- tho I think that has finally changed. Most of the major steel mills have been replaced by recycling/mini-mills and/or specialty mills. Most of the undesirable elements/contamination can be removed... some do it better than others. The "cleanliness" of the steel can be analyzed via several techniques... it just takes time... and money.
R. Smith
Santa Clarita, CA
  #38 (permalink)
Old 04-02-2014, 09:20 AM
ItBites's Avatar
Al,
Glad you think know my business so well, hahaha. You sound like a supplier/salesman.
E. Wood
ItBites
  #39 (permalink)
Old 04-02-2014, 01:10 PM
db replicas's Avatar
Cobra Make, Engine: DB427SC. 289FIA. COUPE. Round tube, Aluminium body, 427FE
It was a completely new chassis manufactured by AC Cars.
We are talking about the early/mid 60's cars here aren't we?
Dave Brookes.
UK Cobra manufacturer/builderhttp://www.db427.com
  #40 (permalink)
Old 04-02-2014, 11:28 PM
Yes we talk about the original MKI & MKII as well as about 427s.
Rate This Thread:
