Like Tree26Likes
Old 10-15-2014, 08:01 PM
LightNFast's Avatar
Cobra Make, Engine: Viking Blue "64" 289 FIA comp car by Superformance #0002, Keith Craft - 331 (460HP), Jim Inglese - 48IDA Weber carbs, BW T10 4spd.
I agree with Jeff and consider vintage photos of 2323 & 2345 at the start of (or at least during) Targa Florio 64' to be the best reference. Mainly because they were the last two "FIA" cars purpose built by AC (including "dimples" btw-) and hadn't been previously raced.
Old 10-17-2014, 08:34 AM
Bill D's Avatar
These are great photos and the information surrounding their development is very useful. I wish someone could build the air ducts in aluminum. That would be the perfect compliment to my car
Old 10-17-2014, 12:37 PM
*13*'s Avatar
Air ducts wouldn't be the difficult to produce in aly. Just need a buck, hammer & someone who can weld
ERA FIA 2088
Old 06-10-2015, 01:43 AM
ALF's Avatar
ALF ALF is offline
Does anyone have some (approximate) measurement results of the mentioned oil scoop opening on CSX2431 cars?
- High of the scoop
- Radius usd
As pictures are often misleading it would help for verification.
Old 06-10-2015, 11:48 AM
CompClassics's Avatar
Like people have stated in this post, no two cooler scoops were alike, here is the scoop that I put on my FIA Cobra....I also manufacture the oil cooler and oil filter housing adapter to install an oil cooler.
1985 CCX likes this.
Old 03-14-2016, 04:05 PM
Bill D's Avatar
Ok, I have fabricated a scoop from .060 6061 aluminum. Three pieces welded together and riveted to the body. I haven't cut out the opening yet. Wanted to run this past you guys first
Old 03-14-2016, 04:45 PM
Bill D's Avatar
After looking at CSX2345 and comparing it to mine, I am unhappy with my result. I moved it forward two inches and it looks much better. However, none of the mounting holes line up and the contour of the body changes causing a huge gap between the flanges and the body. Time for the scrap bin
Old 03-14-2016, 05:20 PM
Your scoop looks good, as Dan C pointed out no two oil cooler scoops were the same. As I had previously mentioned the first two of the purpose built "FIA" roadsters used riveted on scoops.
The rear deck lid dimples and oil cooler scoops were done in SAIs race shop.
The dimples were not the only modification required to fit the suit case in the trunk, there were other parts that needed to be modified as well.
Old 03-14-2016, 07:46 PM
Dangerous Doug's Avatar
The body shape in that picture of CSX2345 sure looks a lot like my ERA 289 FIA...fenders, flares, doors, hood scoop, snout, oil cooler scoop...
If the ERA 289 FIA wasn't based on CSX2345, which FIA car was it based on?
DD
Dangerous Doug
"You're kidding, right?"
Old 03-14-2016, 08:05 PM
Bill D's Avatar
Thanks for the positive reply. I made mine to rivet on.
Bill
CompClassics likes this.
Old 03-15-2016, 05:09 AM
DD
That's the car. Phil went out to Arizona (I think) to go over what is the only unrestored FIA to get the shape and other details.
Old 03-15-2016, 06:22 AM
1985 CCX's Avatar
I like it!
Keep the pictures coming....
  #33 (permalink)
Old 03-15-2016, 12:33 PM
427sharpe's Avatar
Bill D: You are definitely on the right track in the photo, but the scoop begins too far aft. Judging from the other pics, the scoop cutout begins about 3/4 - 1" below the radiator opening (just below where the OE chassis bar would be) and ends before piercing the lower body edge. I am liking this setup--maybe because i am so accustomed to the 427S/C type that anything different (within bounds!) is cool. Keep up the thread so we can see the finished product, please!
Bill D likes this.
  #34 (permalink)
Old 03-15-2016, 01:42 PM
1985 CCX's Avatar
Just weld an alloy bead to the lip, sand and rivet on the body...
  #35 (permalink)
Old 03-15-2016, 02:51 PM
Bill D's Avatar
I agree that the front lip of the scoop needs to be further forward and closer to the lower radiator inlet lip as you said. I have decided to make another attempt with aluminum. I have a friend who is an expert at welding aluminum. He will be my go-to source on the second attempt. I'll keep everyone informed
Bill D
  #36 (permalink)
Old 05-26-2016, 06:22 PM
Bill D's Avatar
After waiting a month for the welder to weld up a second attempt, I finally got my scoop back and installed it today. Much better and more period correct, I believe.
Next, I will fab a shroud for it
My reference source
  #37 (permalink)
Old 05-27-2016, 12:37 AM
ALF's Avatar
ALF ALF is offline
Hi Bill
Get in contact with John (CompClassics)
He can provide you the correct oil cooler to match your great looking shroud.
Check his parts on ebay
289 Shelby Cobra Competition Oil Cooler Assembly GT350 R Model FIA Usrrc | eBay
One of John's happy customers
ALF
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
  #38 (permalink)
Old 06-02-2016, 05:50 PM
Bill D's Avatar
Too far down the road to change directions Alf.
After three days of fabricating, re-fabricating, fitting and trimming the oil cooler shroud, I finally completed this frustrating task. The shroud is three pieces-two sides and a top. It now completely encloses the oil cooler.
I added two plates to the oil cooler to which I attached the side panels.
Then I fabricated several brackets that are behind the side panels. The side panels are attached to these brackets and to the added plates on the oil cooler
And finally the top panel
Upon final installation, countersunk flush mount rivets will be used for a clean look
1985 CCX and peterpjb like this.
  #39 (permalink)
Old 10-23-2016, 03:37 PM
Bill D's Avatar
Ive decided the aluminum scoop I made just doesn't look right. So I got out the template cardboard and laid out a new one. This one has a smaller opening and looks closer to the pics I could find. Now it's time to transfer the template to a sheet of aluminum and have a go
  #40 (permalink)
Old 10-24-2016, 09:16 AM
peterpjb's Avatar
Originally Posted by Dan Case View Post
That's the video.
Allow me to point out that not every Cobra SAI fitted with an oil cooler heat exchanger in front of the coolant radiator got any type of extra front fascia modification to increase the area open for air flow. Based on 1964-65 images I would say that most did not.
that is a good point, several racing cobras in europe don't have any oil-cooler scoop, e.g. cob 6008
i am considering to close my oil-cooler scoop while positioning the oil cooler backwards right under the water cooler ... any doubts?
