Old 01-11-2015, 07:32 PM
Cobra Make, Engine: FFR7993, 390FE
Default Smiths Gauges and comp dash layout
Hi,
I ordered my set of gauges and have a question regarding the oil pressure gauge. The options available are the 100 psi and 160 psi gauges. I've decided to go with mechanical gauges.
I am using a 390FE to power my FFR. It will be a mild build to about 400 hp.
I have seen some CSX cars and photos, and both gauges have been used..
What psi would you recommend and why?
I have searched this forum and did not find any info on the psi this engine should have nor the psi of the gauge.
I would also appreciate it if someone has the measurements to layout the gauges in a comp layout.
Thanks in advance for your help.
Achi
FFR7993, 390FE. IRS
Old 01-11-2015, 07:46 PM
Cobra Make, Engine: Midstates Cobra 350 Chevy Red W/Gold Stripes.
0-100 is big enough. engine oil presure is around 50 to70lbs. Rule of tumb is 10lbs of presure for every1000 RPM of engine rev.
Old 01-11-2015, 07:50 PM
mrmustang's Avatar
Gold Star Contributor
Dash layout & Dimensions
On the FFR, I suggest taking the measurements off your steering shaft opening and adjust the attached measurements from there.
Bill S.
Originally Posted by achi View Post
Hi,
Achi
