06-04-2006, 01:42 AM
Administrator
Wa
Wheel center caps or not?
Ok, this is probably a goofy question, but here it goes....I've seen pictures of vintage cars with and without them. Some with front center caps, but the rears not there. I personally like the raw look without, but....I'm probably wierd.
Did all of the cars come with them on all fours and some/all got lost on the track, or??? Ron (computerworks) probably has this kind of information just floating in all that extra brain matter of his.
Told you it was a goofy question.
06-04-2006, 02:05 AM
Evryday is a roadstr day
Oh
Cobra Make, Engine: RHD Hurricane street roadster HM1081 aging nicely in the garage
All the books I have showing the early road cars, particularly in the book by Dave Friedman showing the sales promo shots, showed cars with wire wheels with knock off spinners taken in early 1964. In the promo shots for the Racing dept., his shots show alloys with knockoffs. Same goes for the coupe photos and the Dragaon Snake. It appears that with the alloy wheels though, there were several types of different knock spinners that could be used.
 aka Fuzzy ............... "It is not the return ON my investment that I am concerned about; it is the return OF my investment"....  ...from Will Rogers
06-04-2006, 02:09 AM
Administrator
Wa
I'm more asking about the little round center cap with the alloys...The thing in the center of the spinner.
Here's an example of csx2260 with a center cap on the fronts but not the back.
06-04-2006, 04:12 AM
On the original cars, the front caps actually sealed the wheel bearing area from dust, so most kept them on. On the rear, they were only cosmetic, so the comp cars didn't use them.
06-04-2006, 07:15 AM
Yup, that's exactly what I was gonna say. Fronts are needed for bearing protection, rears were cosmetic.
I pulled the rears off my car, and I love the way it gives it more of a comp look. And now I have a spare set of fronts  .
Sal Mennella
06-04-2006, 08:35 AM
OR
Great question Brent! I always kinda wondered that myself. I would pull mine but afraid they may be needed???
ERA FIA 2088
06-04-2006, 09:48 AM
Administrator
Wa
Thanks fellas.
I do have the same question as Hyde (*13*). How do you tell if they are needed or not?
06-04-2006, 11:18 AM
If your front pin-drives use adapters on a standard bolt-on hub, the the caps are not needed. The ERA 6-pin system's one-piece hubs need them. I haven't seen a rear design that needed 'em.
06-04-2006, 12:10 PM
I think what he means Brent, is if you are running a real 6 pin setup (like CSXs, KMPs, ERAs 6 pin, etc), then you need them. If you are using the Trigo 5 lug adpaters, then you don't. For your KMP, you need them on the front, but not the rear (just like original cars).
Sal Mennella
06-04-2006, 11:44 AM
Administrator
Wa
Ok, thanks! I'll check on that.
06-04-2006, 12:11 PM
Cobra Make, Engine: ERA #828
I must be as wierd as you Brent, I like the look too. In fact, I'm gonna do like Sal and pull the rear ones off.
06-04-2006, 12:23 PM
Administrator
Wa
Here's the pisser guys...I love the look of them being off, but it for some reason bugs me having the front on but the rear off. It just seems unbalanced...Damn it! Sometimes I hate me.
06-04-2006, 12:30 PM
Want me to take a quick pic of my car with them like that?
Sal Mennella
06-04-2006, 12:33 PM
Administrator
Wa
Sure!!!
06-04-2006, 12:46 PM
Sal Mennella
06-04-2006, 12:54 PM
Administrator
Wa
Thanks for the pics! I'll definately run that way. I may try to come up with a different inverted dust cover for the front to protect but give the no cap look all the way around.
By the way, I like how you removed the paint on the Eagle part of the tires. If/when I get a set of those tires I'll likely do the same. Oh, and you just had to make people dool with the FE shot, right?
06-04-2006, 01:11 PM
Hehe, yeah. I spent a LOT of time and effort on that motor, making sure every nut, every bolt, every wire, bracket, clamp, etc was as correct to an original as I could. Lots of photos, questions, and buying wrong parts  . But I am really happy with how it came out. Other than the obvious block difference (it's a 390), the rest of the motor is pretty much exact to an original (save for one or two items I haven't changed yet).
Sal Mennella
08-05-2006, 10:27 AM
GA
Do tell.....
Power Surge,
Can you share the details on your "original" engine build? It would be interesting and informative to hear about what you found through your research. For example, given my recent trials with blow-by, I'm curious to hear how that was addressed on original engines. Was the only venting the oil recovery tank on the firewall with a line from the rear breather hole on the intake? How did those oil tanks work? Did you just have to empty them, or did the oil run back in to the crankcase?
Thanks!
Scott
08-05-2006, 10:53 AM
Originally Posted by HSSS427
Power Surge,
Thanks!
Scott
I don't have any blow by issues on my motor so I can't say. My motor is vented like original, with the oil fill breather cap, and the rear line going to the puke tank. The puke tank is just a vapor tank, but in the event that the vapor condenses and turns back into liquid oil, one of the lines runs back down to the Aviaid oil pan. That's what the big port on the front of the pan right behind the dipstick fill port is for.
Hope this helps.
Sal Mennella
06-04-2006, 01:24 PM
Super Moderator
Leave 'em off the rear.
Jamo
