Old 10-01-2006, 06:03 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Fuel Pump
Can anyone identify what the original S/C's used for a fuel pump.
Electric or Mechanical
If mechanical, which version w/ or w/o Canister filter.
If a separate filter was used, where was it located?
Thanks
Paul
Old 10-01-2006, 06:09 PM
computerworks's Avatar
Original S/Cs (and Comp cars) used a mechanical fuel pump with the standard separate Ford canister filter up by the distributor, not mounted on the pump. It was supplemented by two electrical pumps in the trunk that were used as a 'reserve' and controlled by a dash-mounted switch.
The line from the trunk-mounted pumps met at a tee-fitting on the mechanical pump.
Old 10-21-2006, 07:55 PM
PaulProe's Avatar
Default Fuel Filter
Ron,
Gonna have to paint your name on my car as a major contributor
Do you have a picture of the filter setup, or part number of the filter. I've found the bracket but not the filter
Thanks
Paul
Old 10-21-2006, 08:05 PM
Here's a pic from Tony (Naumoff)'s engine that shows the cannister-style filter.
From this thread:
wanted: 427 Original style fuel filter
Old 10-21-2006, 09:42 PM
LMH's Avatar
LMH LMH is offline
Wow, is that a spectacular engine or what!
Old 10-21-2006, 10:20 PM
Rick Parker's Avatar
I'll bet the dipstick gets pretty warm?
Rick
