09-23-2006, 06:05 PM
IN
Cobra Make, Engine: Kirkham, Pond Aluminum 482FE
WTB Holley 750cfm HP 80528
Want to buy a Holley 750 cfm HP race carb with vac. secondaries. Holley part no. 80529. They're on eBay for under $400, so I'm looking for a bargain. This is for an experiment...
edit: 80528 with mechanical secondaries, please.
09-23-2006, 10:05 PM
Joe your car is too light for a vacuum secondary setup. Go with mechanicals if you can.
09-24-2006, 04:21 PM
OH
Originally Posted by HotRodJoe
Want to buy a Holley 750 cfm HP race carb with vac. secondaries. This is for an experiment...
What's the experiment ?
09-24-2006, 04:33 PM
Check with Jegs or Summint online...
09-24-2006, 06:04 PM
SC
got mine on EBAY
09-24-2006, 06:13 PM
in
Cobra Make, Engine: Hurricane 1022-BOWTIE
Joe,
Go with the mech sec.
Did the car run any better after we reset the timing?
Sid
09-24-2006, 06:50 PM
WA
Cobra Make, Engine: SPF2089
With only 450 hp the rear wheels on the dyno, I can understand changing the carb.
dblbarrel
09-25-2006, 08:18 AM
IN
Sid - it is a little smoother with less "kick", so I think that solved one problem, but I'm still rich most of the time and it acts like my plugs are needing replacement already. Thanks for the help!
Sid / Scott - mechanical secondaries it is!
Dblbarrel - horsepower isn't the problem...
09-25-2006, 08:45 AM
in
Joe,
Here is the MSD # from Jegs (121-8984) $93.00, lock your timing install this so it will start and it will idle cleaner and also make it feel better on the low end.
Sid
