07-19-2009, 09:09 PM
KS
Cobra Make, Engine: jbl
street tire or slick
is the delineation between the two whether it is dot approved or not? so a kumho v710 would be considered street tire?
07-20-2009, 05:11 AM
OK
Yes,
But, in the past classes have been also diveded by those street tires whose tread ware rating is 200 or lower is considered a PREPARED CLASS TIRE and all those tires with tread ware rated at 201 or higher are considered STREET Class TIRES.
Clois
"Let's roll"
"Be part of Something Good
07-20-2009, 05:25 AM
mo
  I agree Life is way to short to worry about gas milage.Other rides Crewcab Super Duty F350 Ford,Shlby Charger,66Mustang/Frankinstang,Chevy Van,KTM Dualsport,FFR Daytona Coupe SOLD... RUN N GUN 06,07,08,09 Hallet 09,
07-20-2009, 05:30 AM
mo
Clois what was the cut off for small block?
07-20-2009, 06:51 AM
KS
399/400ci cutoff for classes, so if i have a 406 i have to run with bills 408? how much faster are the guys running bb's w/450+ ci's?
i see the v710 is rated at 30, so that would be considered slick, thanks for the clarification.
07-20-2009, 07:14 AM
OK
NO, the V710 would not be a slick but a DOT tire that can be ran on the street and with a treadwear rating of 30 you would fall in the Prepared BB class which usually has the fewest competitors. Last year there were only three or four in that class.
Based on what you have told me you would be running in the BB-Prepared Class
Small blocks are anything under 400 cu in.
By the way the 351 bb configs usually out perform the FE style BB.
Clois
"Let's roll"
mo
Ther not I was thinking Morrises winged Kirkum is the fastes BB but he is in pro class SBF's SBC's hold ther own  out ther unless we were talking drags but thats been nixed
07-26-2009, 12:42 PM
fl
Cobra Make, Engine: Backdraft #985 Custom Pro/ Street Race Car, full cage, dry sump 427W and G Force T-56 Fully Street Legal!!
Did someone say drags??
That V710 is an excellent tire, I had been running them for a couple of events, very sticky when hot, and it almost seems like there are an unlimited amount of heat cycles. After these R6s run out of life, I'll most likely go back to them.
BB prep is a diversified class, a little bit of everything.
Gettin close.......
Life is short, live like you mean it!!
Live every day like it's your last. One day you will be right!
07-26-2009, 05:43 PM
OK
I hope you make it this year Richard. I missed our on track competition last year. I may never be as fast as you but I will offer a little more competition than I did a couple of years ago.
If fate works in my favor I may have a my coupe ready for this years Run N Gun. I am thrashing on mine so keep thrashing on yours.
Clois
"Let's roll"
07-27-2009, 11:48 AM
fl
Back to the classes. Wouldn't this fall into the new GT/2A Prep class?
Looks like a pretty good chance that I'm in for this year, only ten more weeks to figure out how to drive....
07-27-2009, 01:19 PM
mo
07-27-2009, 01:53 PM
fl
Yeah, it's pretty clear, over 2000 lbs, and over 400CI is in together. It certainly adds a little spice to the mix.
07-27-2009, 03:01 PM
KS
looking at tires and from what i understand, khumo v710 last longer not so sticky, hoosier r6 stickier then 710's for 5-6 cycles then fall off.
anybody have experience with other brands? something that stays sticky forever and doesn't wear out too quickly?
07-27-2009, 03:29 PM
mo
Hmmm stays sticky forever and dosnt wearout to quickly no such tire.We run A6's on the back R6's in front.And had good fortune with that combo last year  .Morris runs A's allround most know how fast he is What did the pro from BD run last year?
07-27-2009, 03:58 PM
fl
I believe they were all out slicks, not DOT tires.
07-27-2009, 06:26 PM
mo
Getting my A$$ kicked by cars that have 150 or more HP than I do doesnt sound like that much fun right at the moment.
07-27-2009, 09:36 PM
KS
wonder since our cars are lighter if the a6 would be better then the r's, especially if running in cooler weather. need to call hoosier and see what the compound is similiar to for comparison.
07-28-2009, 03:23 AM
fl
Bill, that's still better than having you butt kicked by a car with 150 LESS hp
07-28-2009, 04:12 AM
OK
I think Tony Martin could probably run "May Pops" and turn incrediable times because he is just that good of a driver. But, back to the subject of tires, I think both Tony Martin and Reg Dodd were running slicks on their Backdraft cars.
Richard I thought you were running slicks all the way around the last couple of years?
Clois
"Let's roll"
mo
Ok well you have a piont ther.I have been on the short end of the stick before its just when thers comparable engines it comes down to setup and drivers not HP I would rather get beat by a better driver in a slower car than get outgunned under the hood .The A6's wont overheat in the cool weather in fact my last timed run near the last lap of the session is when I had my lowest time and that was on used tires.Give Fossport an email they did us good.
