February 2026
Like Tree2Likes
  • 2 Post By
Old 07-29-2012, 12:14 AM
Jac Mac's Avatar
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
You should not have any problems with the 300zx rear end, Ring gear is 230mm/9" dia & axles are tough, wheel stud pattern is same as ford ( 5 on 4.5" pcd) half shafts are one long/one short so you should be able to get it narrow enough for the cobra by using two of the short ones if necessary. Several running out here in OZ & NZ behind big Fords & Chevs.. Keep your eyes open for a Toyota Supra front end of 90's>> vintage, same stud pattern, as a donor for your front end. The S/H body is a good idea, a couple for sale privately in the site at moment IIRC, look at my gallery pics--- lots of work in a buck!!!
Jac Mac
Old 08-09-2012, 09:20 AM
Dominik's Avatar
Hi Dave!
I got a rough idea about what possibilities you explore. Get a body with main tub first.
There should be some around for $1.500, even if damaged. Then place the drivetrain. You will find a few measurements where the engine sits off the ground and from the front here. If not, ask.
Then position your wheels under the body, with tires. Work from here inwards to your chassis (that you make?).
Ground clearance for the 4" tube chassis is 5".
In the rear the block rests on a 3/4" square channel.
If I don't respond anymore, that's because I can't log in
