163Likes
10-09-2013, 11:18 AM
va
rear brakes
Got the brackets right first time, (all ways good to have a little luck) hopefully we will get started on the body soon! This wraps up most of the frame and suspension.
04-30-2014, 08:09 AM
va
fuel tank
It has been a long cold winter, not to much work on the scratch build, I have 3 cars in the shop I need to build fuel tanks for, so I am starting out making the straps that hold the fuel tank in place. I am making the hooks out of Stainless, one less thing to get powder coated.
08-03-2014, 06:47 PM
va
Slow
Slow progress on the scratch build but hopping to get the body and frame together soon.
08-03-2014, 06:55 PM
va
slow
Had trouble loading a couple of pictures, here is a couple of the body.
08-03-2014, 07:36 PM
Awesome, just awesome! Beautiful workmanship!
Alba gu brąth
09-20-2014, 06:26 AM
va
two step back
It's funny how sometimes a project takes a couple of steps backwards before it can gain one step forward, But I decided to use a set of our control arms so off with the old and on with the new!
So here we have a picture of a front lower control arm just out of the jig, front upper and lower control arms back from powder coating and mounting the front lower to the frame.
Cheers.
09-20-2014, 01:42 PM
Some people have the talent! I'm envious.
09-20-2014, 04:02 PM
Full Blown Member
How did I not ever catch this thread? I had no idea.
I wish I could do what you do.
Awesome work.
rodneym
09-20-2014, 04:06 PM
Awesome work.
His work is spot on. Its so good I'm trailering my car to his shop for some upgrades.
09-22-2014, 12:20 PM
va
Thanks for the kind words. I am looking forward to working on your HiTech.
HiTech is one of my favorite cars.
See you soon.
09-23-2014, 05:07 AM
va
Here we have installed the lower ball joint, then spent some time on the lathe and machined the spacers for the upper control arms.
I then installed the upper control arms with the spacers and rod end seals.
09-23-2014, 05:10 AM
va
Front upright then can be installed.
09-23-2014, 07:02 AM
UK
Cobra Make, Engine: DB427SC. 289FIA. COUPE. Round tube, Aluminium body, 427FE
Great pictures kiwi
I have been doing the same thing here in the UK.
I have found that the steering arm with a bend like you have there causes crazy amounts of bump steer.
To get the bump steer to zero the steering arm ball joint needs to be 40mm ( 1.5"+) further outboard. However, this causes major problems with the original spec brake rotors, and of course the steering arm need to be re shaped.
To get around this I use a different rotor that I have to modify to fit the 6 peg hub. and a different brake calliper.
Take the steering arm from the other side of the car as it requires less "bending" in order for it to put the pivot point in the ideal place.
09-23-2014, 03:19 PM
va
Originally Posted by db replicas
Great pictures kiwi
Thanks for the tip.
09-30-2014, 06:13 PM
va
Got the front hubs and rotors mounted
10-02-2014, 12:46 AM
Keep it up!
It can be tedious, I know... You're not only building a car, but also your character.
Especially the patience and (non-) temper side of your brain - if any of such is left ;-)
Which reminds me, I should get off this Mac and follow up on the suspension of my car.
10-02-2014, 04:26 PM
va
Bolting and unbolting a few parts is not a big deal, getting from this to this is where the patience is tested.
10-02-2014, 07:35 PM
Very cool!
Alba gu brąth
11-18-2014, 07:54 PM
Az
Cobra Make, Engine: Soon to be a hurricane
Wow!!!!
12-09-2014, 02:40 PM
va
Thanks Larry,
Nice talking with you the other day Chaz255.
Finished up the front steering arms and got the hubs, brakes etc all mounted.
Time to put this one down on its wheels again.
