119Likes
11-15-2015, 03:36 PM
va
Thanks for the complement Jeff,
I really do appreciate all the positive comments.
Originally Posted by 1985 CCX
Work of art!
You do great work and belong in the scratch builders hall of fame.
11-15-2015, 03:47 PM
va
I was able to get a few hours in today on the build, I made a few more panels for the trunk, I need more clecos to finish the trunk up, (on order) then I made the dash panel up.
11-21-2015, 03:40 PM
va
Made up a few more panels over the last couple of days, finished the lower rear bulkhead panels.
Installed the radiator so I could start on the panels in the nose of the car.
11-21-2015, 04:00 PM
va
After making the panels around the radiator, I was able to finish up the nose panels, then move onto the panels for the oil cooler shroud.
This is about it for alloy work forward of the rad.
11-28-2015, 09:35 PM
convert edrw to CAD
Nice spare wheel insert (trunk floor)!
I had my laser cut people digitise one of my fibre parts years ago and it came out quite well, including the rivet holes and bend/fold lines.
Unfortunately I only have the SolidWorks file left (the CAD is lost) and can't make the part anymore..
I tried to upload, but the file format is not supported. Anybody who wants it, drop me a PM. I hope somebody can convert it back to a CAD. It's not 100% refined yet. If I remeber correctly I need to add some clearance along the bends.
12-10-2015, 01:45 PM
va
Dominik,Thanks for the positive comments, you should start a thread and show your builds. Sounds like you have built some nice stuff.
I got to make a couple more panels today.
12-17-2015, 05:05 AM
va
I was able to finish up the inner front panels,
12-30-2015, 01:43 PM
va
The last couple of days I have worked on getting the foot box's and firewall in place.
12-30-2015, 01:58 PM
Tn.
Cobra Make, Engine: Lone Star Classics- 351W
All I can say is……DAMN!
01-02-2016, 07:34 AM
Cobra Make, Engine: Hi-Tech 427 Comp by Craig Coombe
Wish Santa would have left that in my stocking, Craig.....amazing.....wanta trade for a nice Hi-Tech
01-02-2016, 07:56 AM
Some real impressive work. Wish I had the skill level that you do!
01-02-2016, 12:02 PM
Senior CC Premier Member
Simply outstanding work! Keep it up and keep the updates coming!
01-04-2016, 03:32 PM
va
Bill,
there were a few things Santa could have left for me as well, I will take your HiTech in on trade, you have my Number
Thanks for the great comments guy's!!!
Got to work on the passenger side floor today.
01-04-2016, 04:17 PM
Craig
You are a master......😎
Comment, on original cars the alloy under door hinge is two peice. Allows the hinge pin to fit through bottom.
You have the angle to be able to insert?
Just an FYI before installing.
Jeff
01-04-2016, 04:59 PM
va
Craig
Jeff
Jeff,
good point, just not there yet, as you point out there needs to be a cut made to make clearance for the door hinge bolt to be installed and removal.
I like to make the floor board in one part then cut, I just find it a little easier to hold and fold everything.
Here is a picture of the cut that needs to be made, this is the floor board from one of our other 427 cars.
01-04-2016, 05:13 PM
The master
Awesome.
01-04-2016, 06:10 PM
Craig - That looks absolutely awesome. Keep the pictures coming...
01-06-2016, 02:46 PM
va
Thanks Kevin,
Hope to see some progress on your build soon.
01-08-2016, 02:31 PM
va
Floors are just about finished, had time today to make up the trans tunnel.
Just about time to start drilling and cutting holes in the body
01-08-2016, 03:33 PM
Full Blown Member
cobrakiwi,
How long does it take you to make a roller from start to finish?
rodneym
