Like Tree119Likes
  #61 (permalink)
Old 01-13-2016, 06:11 PM
cobrakiwi's Avatar
Originally Posted by rodneym View Post
cobrakiwi,
How long does it take you to make a roller from start to finish?
Rodney
Hard to say really, all depends on options and the big one is some of the vendors I use.
Also it seems I always have two or more projects going at the same time, including my own cars.
I would like to get to a point were I have a small quantity of parts in stock ready to go.
  #62 (permalink)
Old 02-02-2016, 01:40 PM
cobrakiwi's Avatar
Default tech tip
Today's Car building Tech Tip, measure at least 4 times then cut your holes!
Got to mount the hood scoop today, this process requires measuring a lot, then with a steady hand cut the holes.
  #63 (permalink)
Old 02-02-2016, 01:49 PM
cobrakiwi's Avatar
Next up, install the hood latch handles.
Car is off to paint, happy to be at this stage of the build
  #64 (permalink)
Old 02-02-2016, 02:13 PM
Bernica's Avatar
Senior CC Premier Member
VERY NICE!
So, what is the paint scheme?
  #65 (permalink)
Old 02-03-2016, 04:40 AM
cobrakiwi's Avatar
VERY NICE!
Thanks!
My client is leaning towards a dark blue, no stripes.
  #66 (permalink)
Old 02-03-2016, 05:11 AM
1795's Avatar
Sounds nice. Very good craftsmanship! Can't wait to see pictures after the painting is completed!
  #67 (permalink)
Old 02-04-2016, 07:35 PM
Cobra Make, Engine: Shelby Continuation Cobra CSX 6066
Simply amazing, wish I had your talent. Do you offer apprenticeships?
  #68 (permalink)
Old 02-05-2016, 03:26 PM
cobrakiwi's Avatar
The old apprenticeship days, I kind of miss them actually, you had to stay on your toes in our shop back in the day, if not it always ended in embarrassment or pain!
Thanks for the comments.
  #69 (permalink)
Old 02-05-2016, 04:03 PM
1985 CCX's Avatar
Craig
Did you center the hole?
It is supposed to be offset inch to right.
  #70 (permalink)
Old 02-05-2016, 04:08 PM
1985 CCX's Avatar
  #71 (permalink)
Old 02-05-2016, 04:14 PM
Bernica's Avatar
Yeah, I have a 1/2" shim under drivers side motor mount to try to fix just that! Then, your passenger side header pipes coming out of the body start to rub the bottom of the body outlet. THEN, you end up with the driver's side throttle linkage up against the head / headers. It's something of a conundrum that has haunted me for a while...
  #72 (permalink)
Old 02-05-2016, 04:55 PM
cobrakiwi's Avatar
Craig
Hey Jeff,
yes I did center the hole, I also make the opening a little wider as well, my thinking, more cold air in when driving, more hot air out when stopped.
I also always try and run the ford sidewinder intake, that pulls the carburetor back close to center.
Even with a center carburetor setup the small air cleaner and turkey pan will sit under the cut out.
Turkey pan is plenty wide enough to catch the cut out.
Thanks for keeping me straight
  #73 (permalink)
Old 02-05-2016, 05:02 PM
cobrakiwi's Avatar
Was the air cleaner interfering with the hood cut out?
  #74 (permalink)
Old 02-06-2016, 07:20 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Great job on the hood - it looks awesome. I have a Blue Thunder intake manifold and my carb is offset towards the passenger side about a 1/2".
  #75 (permalink)
Old 02-06-2016, 09:02 AM
Bernica's Avatar
It wasn't lining up so I had to either use a shorter air filter or move things over. I think in my case, the problem was compounded by the way Shelby installed the footbox.
  #76 (permalink)
Old 02-09-2016, 01:02 PM
cobrakiwi's Avatar
Neutral
More parts ready for powder coating, these are the control arm covers that go behind the seats and in the trunk.
I never did like the fiberglass ones as they never seemed to fit that well.
rodneym likes this.
  #77 (permalink)
Old 02-10-2016, 03:27 PM
Hawg4Fun's Avatar
simply awesome metal artisanship on both these builds Craig!
i am back in the Cobra hunt may buy an ERA near Bealeton, VA is that any where close to you? i am looking for someone to go look at it for me...all the best KB
  #78 (permalink)
Old 02-10-2016, 04:13 PM
cobrakiwi's Avatar
Thanks KB
Looks like your guy's had a good day Sunday.
I will be in touch.
  #79 (permalink)
Old 06-17-2016, 03:26 PM
cobrakiwi's Avatar
Finally have this car back from paint, took a little longer than expected but very happy with the outcome.
I would put my paint guy up against anybody, he did an outstanding job!
This is the first Blue car I have built, my customer selected the color and I must say I think it looks great.
Bill we may be able to pass it off as a real one
Now the fun part, bolting it together for the final time
  #80 (permalink)
Old 06-17-2016, 03:28 PM
Bernica's Avatar
Beautiful!
And, obviously I like the color! Just look at mine. Pretty close!!
