Like Tree574Likes
  #121 (permalink)
Old 09-02-2016, 01:54 PM
Bill D's Avatar
Cobra Make, Engine: FFR chassis and suspension, Mr. Bruce 289 FIA body
This is such a cool build to follow. I'm in awe.
cobrakiwi and ScratchBuilder like this.
  #122 (permalink)
Old 09-03-2016, 06:54 AM
Originally Posted by MAStuart View Post
Mongoose and Scratchbuilder The ends on those control arms could be brought into alignment with heat in the right place and letting it cool. Its called flame straightening . No manual bending involved. What you see there happens all the time even when it is welded in a jig. If all the jig holes were nice and tight and you fully welded your part you would probably have a hard time getting your part out of the jig. And you would have a harder time getting it back in the jig.
Mark
Mark if you had seen the abortion of metal that came from acton like I have on SB's control arms or any of the FUBAR crap that he sent to me you would see that the pieces were far beyond ever being straightened or aligned to anything more than scrap metal
  #123 (permalink)
Old 09-04-2016, 08:32 AM
cobrakiwi's Avatar
Cobra Make, Engine: Coombe, Shelby Block 496
Kevin opted to go with new shocks and spring rates more suited to the intentions he has for his car when finished.
Once I have the body completed all the suspension arms will be removed for fresh powder coating.
1985 CCX, Bill D and era cobra like this.
  #124 (permalink)
Old 09-21-2016, 11:12 AM
cobrakiwi's Avatar
Default Fuel cap
Kevin opted for a lockable fuel cap, (good idea I think) problem was the hole spacing and screw type for mounting are not per original.
To fix this I welded up the old mounting holes, machined the flange and will drill new holes with correct spacing, we will also be using vintage bolts etc to mount on the car.
era cobra likes this.
  #125 (permalink)
Old 09-21-2016, 11:47 AM
Bill D's Avatar
Wow! Great attention to detail
  #126 (permalink)
Old 09-23-2016, 11:27 AM
cobrakiwi's Avatar
Thanks Bill,
this is just the start of many details we are/will be incorporating into this build.
Kevin is really stepping up with many neat parts and ideas, as well as parts we are making for this car is truly going to make it a very special build.
  #127 (permalink)
Old 10-13-2016, 04:11 PM
cobrakiwi's Avatar
Christmas has come early, all the way from the UK.
Two wire harnesses, one for Kevin's car and one for me!
1985 CCX and LMH like this.
  #128 (permalink)
Old 10-14-2016, 08:54 PM
era cobra's Avatar
Cobra Make, Engine: Contemporary 302 Ford stroked to 347
Looking forward to seeing the finished car. Keep up the great work.
  #129 (permalink)
Old 10-17-2016, 06:22 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
While my alloy body is being built, I figured I would get a couple other projects underway. This will be a replica of an early Comp car so I wanted to go with FIA wheels. I spoke with Curtis at Trigo and he gave me a great deal on various color powder coated wheels left over from when he made his website. I had the wheels shipped to Craig to have them “modified”. One quick way to tell if a wheel is magnesium vs. aluminum is the location of the valve stem. For alloy wheels, the valve stem holes are in front of an "open" section of the wheel but Craig has moved them in front of the "closed" sections, just like magnesium wheels. After that, he welds up the original holes like they never existed. I know it is a small detail, but it is definitely something I wanted for this project. The first two pictures are "before" and the last two pictures are after Craig worked his magic.
1985 CCX and Bill D like this.
  #130 (permalink)
Old 10-17-2016, 08:01 PM
It's the small details like this that really make a build stand out from others. Looking forward to any other ideas you have coming up on this build....
Bob
cobrakiwi and cycleguy55 like this.
  #131 (permalink)
Old 10-17-2016, 09:51 PM
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
That all gold FIA is giving me a chub!
Great mod Craig !
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
  #132 (permalink)
Old 10-18-2016, 02:54 AM
cobrakiwi's Avatar
Great mod Craig !
Thanks Mike,
I would have guessed that all white wheel would have been the one to get your crank turning!
  #133 (permalink)
Old 10-18-2016, 01:25 PM
1985 CCX's Avatar
Correct valve stem placement.
Probably the first time efforts like this have been done on alloy.
Let the copycats take note.
cycleguy55 likes this.
  #134 (permalink)
Old 10-18-2016, 06:42 PM
It took almost a year but my original style adjustable seat tracks finally arrived!!! I should have added my Leveroll knobs before taking the picture.
cobra, 1985 CCX, LMH and 2 others like this.
  #135 (permalink)
Old 10-18-2016, 08:58 PM
cobrakiwi's Avatar
Kevin
outstanding!
Can't wait to see these in person!
  #136 (permalink)
Old 10-18-2016, 09:22 PM
Cobra Make, Engine: Scratch Built with 482 FE
Nice hardware!! Vendor?
  #137 (permalink)
Old 10-19-2016, 05:51 PM
1985 CCX's Avatar
Sweet Jesus! Fantastic.
KevinW likes this.
  #138 (permalink)
Old 10-23-2016, 02:10 PM
cobrakiwi's Avatar
This is one of the seats that will top a set of those seat tracks.
cobra and KevinW like this.
  #139 (permalink)
Old 10-23-2016, 02:29 PM
1985 CCX's Avatar
Looks familiar
  #140 (permalink)
Old 12-06-2016, 03:50 PM
cobrakiwi's Avatar
I will be starting the fabrication on the clutch and brake pedals hopefully soon for Kevin's car.
Here is my pattern/template pedal and parts we will be using.
We have some really nice and interesting parts inbound for this build.
Tags
acton, mickmate
Rate This Thread:
