Like Tree574Likes
  #341 (permalink)
Old 10-21-2018, 10:16 AM
cobrakiwi's Avatar
Brakes,
The brakes we are going with are the Wilwoods front and rear, (for now) we talked long and hard about this as Kevin would very much like to go with the original Girlings, and we may some day.
We both agreed if the Wilwoods are going to be used the calipers appearance had to change.
This is what I came up with!
Both Kevin and I like the finished look.
1985 CCX likes this.
  #342 (permalink)
Old 10-21-2018, 11:59 AM
1985 CCX's Avatar
Nice look on calipers and also saving $$$$$
cobrakiwi likes this.
  #343 (permalink)
Old 10-21-2018, 02:06 PM
Cobra Make, Engine: NAF 427
Fantastic build.
Just curious. What size front and rear master brake cylinders are you using?
Greg
  #344 (permalink)
Old 10-21-2018, 04:23 PM
LMH's Avatar
LMH LMH is offline
Nice job on the calipers. Dave Wagner does that on his cars too. Gives it a more vintage look.
Alba gu brąth
  #345 (permalink)
Old 10-22-2018, 02:47 AM
1795's Avatar
Almost looks like a Girling...nice job on adjusting the look to be more vintage Craig.
1985 CCX and cobrakiwi like this.
  #346 (permalink)
Old 10-22-2018, 03:02 AM
xb-60's Avatar
Impressive!
Sometimes, it doesn't take much to make it look period correct and get away with more modern gear. Just need to stand back, obtain a better perspective....and the solution often becomes clearer.
Well done!
Glen
  #347 (permalink)
Old 10-28-2018, 07:06 PM
cobrakiwi's Avatar
Dash going together, gotta love the shinny bits.
cobra and 1985 CCX like this.
  #348 (permalink)
Old 11-03-2018, 08:01 AM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Took a drive to VA to visit Craig and the Cobra. I was very happy with the progress but even happier with the incredible workmanship and attention to detail. My car will be back on the ground soon and making lots of noise!! I have attached a few pictures of the interior. Wilton wool carpeting and leather are amazing.
cobra, 1985 CCX and KevinW like this.
  #349 (permalink)
Old 11-03-2018, 08:10 AM
Always been curious how to get a neat finish on the vynil round the FIA suitcase bulge. How do you cope with the corners? Is it stitched together?
Crendon 427, in the making
http://crendonreplicas.com/
  #350 (permalink)
Old 11-03-2018, 10:07 AM
How did you get the finish on the Wilwood calipers? It looks like their new
mil-spec type III anodizing minus the Wilwood logo. Did you simply just
bead blast their original type II black anodizing off? I like the look!
  #351 (permalink)
Old 11-04-2018, 04:47 AM
Craig and I worked with British Wiring to make a harness that looks period correct where it can be seen, but incorporates many modern safety features hidden behind the dash. Craig has been using the original style wire clamps and aluminum wire ties. I am very happy with the results.
  #352 (permalink)
Old 11-04-2018, 04:54 AM
Here is some of the "modern" wiring hidden behind the dash. Thanks PatrickT for sharing some of your expertise!! Craig made a custom bracket to hold the modern fuse box, relays and Maxi fuse. Very clean and tidy installation.
  #353 (permalink)
Old 11-04-2018, 04:55 AM
It's Alive!!!
  #354 (permalink)
Old 11-05-2018, 07:15 PM
cobrakiwi's Avatar
Yes, The top corners are stitched.
  #355 (permalink)
Old 11-05-2018, 07:20 PM
cobrakiwi's Avatar
The black finish was removed with media blast, I am going to hold off on what I used for the coating as I want some test miles on things to make sure its going to do the job.
Very happy to this point with the outcome.
  #356 (permalink)
Old 11-05-2018, 07:24 PM
cobrakiwi's Avatar
Front calipers assembled and installed.
  #357 (permalink)
Old 11-06-2018, 12:48 AM
AC Ventura's Avatar
Cobra Make, Engine: AC Cars Limited, 302 EFI
Can I ask if the fuel pressure gauge is electronic or capillary? Also is it possible to have a low pressure light or buzzer?
  #358 (permalink)
Old 11-06-2018, 03:53 AM
cobrakiwi's Avatar
Fuel pressure gauge is electronic on this one. I don't see why you couldn't add a low pressure switch as well to the system.
  #359 (permalink)
Old 11-13-2018, 06:43 AM
cobrakiwi's Avatar
The start of a new part for the car,
HTM101 likes this.
  #360 (permalink)
Old 12-05-2018, 05:51 PM
Tank progressing...
Tags
acton, mickmate
