Like Tree574Likes
  #361 (permalink)
Old 12-05-2018, 06:55 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Tank Completed...
1985 CCX and jehammer1952 like this.
  #362 (permalink)
Old 12-05-2018, 06:59 PM
Tank Installed...
cobra, 1985 CCX, LMH and 2 others like this.
  #363 (permalink)
Old 12-06-2018, 05:56 AM
cobrakiwi's Avatar
Nice pictures
The big aluminum box sure does fill the rear end up!!
1985 CCX likes this.
  #364 (permalink)
Old 12-06-2018, 06:28 AM
1985 CCX's Avatar
Craig
You making tanks?
  #365 (permalink)
Old 12-06-2018, 03:20 PM
cobrakiwi's Avatar
Craig
You making tanks?
Hey Jeff
I sure do, you need one?
  #366 (permalink)
Old 01-05-2019, 10:48 AM
cobrakiwi's Avatar
Now that the holidays are out of the way it's time to get cracking on this build.
Had a huge delay with my powder coating guy but I think we are back on track now.
Engine time,
mounted the fuel filter assembly finally ( powder coating delay) then made up some nice stainless lines.
Double flare AN ends.
  #367 (permalink)
Old 01-11-2019, 07:54 AM
cobrakiwi's Avatar
Fuel lines for the engine finished, fabricated the fuel log to feed the race bowls for the Holley.
Made up the bracket to mount the oil filter adapter.
Got the alternator mounted, pulleys spaced correctly.
Started working on something to fit behind the cover under the alternator.
cobra, 1985 CCX, LMH and 4 others like this.
  #368 (permalink)
Old 01-21-2019, 12:51 AM
Send a message via AIM to Hoodabest
Nice tank. Question, did you TIG weld the tank, or torch? The cleaning lines look so nice that my novice eyes can't tell.
  #369 (permalink)
Old 01-21-2019, 09:46 AM
db replicas's Avatar
Cobra Make, Engine: DB427SC. 289FIA. COUPE. Round tube, Aluminium body, 427FE
Will that alternator pulley clear the suspension tower?
Beautiful work as always. ;-)
Dave Brookes.
UK Cobra manufacturer/builderhttp://www.db427.com
  #370 (permalink)
Old 01-21-2019, 10:04 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
I'm sure Craig will chime in but in my case, I have my alternator down low in that location due to the Twin Paxtons. Get the right size belt and there's ample space.
db replicas likes this.
rodneym
  #371 (permalink)
Old 01-21-2019, 04:30 PM
cobrakiwi's Avatar
I use a Tig.
  #372 (permalink)
Old 01-21-2019, 04:33 PM
cobrakiwi's Avatar
The hipo alternator pulley should just sneak in there I believe.
We should know for sure very soon
  #373 (permalink)
Old 02-23-2019, 07:19 AM
cobrakiwi's Avatar
Next up, making the remote oil filter and cooler lines.
Also making the fuel lines up.
  #374 (permalink)
Old 02-23-2019, 10:56 AM
1795's Avatar
Looking nice Craig. The thing I dread the most is making oil lines and fuel lines, it is too easy to get them too long an have to cut them back, or even worse, too short . Also, with the braided steel ones invariably my fingers become sore due to the puncture wounds from loose steel wire braids.
  #375 (permalink)
Old 02-26-2019, 06:52 PM
Wheels came out better than I could have imagined. So nice that I treated them to a new set of Avons...
Cobra should be on the ground over the next few weeks. Can't wait!!
cobra, 1985 CCX, LMH and 3 others like this.
  #376 (permalink)
Old 02-27-2019, 06:19 AM
cobrakiwi's Avatar
The wheels turned out great, it was an exciting day to see the wheels finished and mount the new rubber.
Here is a couple more pictures of the wheels.
cobra, 1985 CCX and jehammer1952 like this.
  #377 (permalink)
Old 02-28-2019, 02:44 PM
cobrakiwi's Avatar
Next up are the rear wheel inner fenders.
This side is just about wrapped up.
1985 CCX, jehammer1952 and Jdata like this.
  #378 (permalink)
Old 03-01-2019, 04:46 AM
Cobra Make, Engine: Self built (Aircar)
what is the coating used on those wheels it is awesome, ???
  #379 (permalink)
Old 03-03-2019, 07:35 AM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
On the fuel flare, I thought I was the only person to cheat the stainless to AN.
With the seam, I couldn't get a regular AN flare to seal, so I played with it and did a double flare (I think those are 45 degrees) then "fixed the angle with an AN (37 degree, but going from memory I may have the 2 swapped) flair tool.
I had quite a bit of these. My car is EFI and I wanted all fuel lines except a few feet for flex from the frame to engine to be 3/8" stainless. I didn't trust aluminum tube to not workharden then crack. At 40psi, a crack can spray a LOT of fuel.
So, were you able to find a tool to make a double AN flare, did you correct the angle with a second flare tool, or just leave the flare the wrong angle?
Thanks for all the pics. Glorious!
  #380 (permalink)
Old 03-03-2019, 07:56 PM
cobrakiwi's Avatar
Thanks, we like the outcome as well on the wheels.
The coating is a powder coating we came up with.
Tags
acton, mickmate
