| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
574Likes
12-05-2018, 05:55 PM
Cobra Make, Engine: Hi-Tech
Tank Completed...
12-05-2018, 05:59 PM
Tank Installed...
12-06-2018, 04:56 AM
va
Cobra Make, Engine: Coombe, Shelby Block 496
Nice pictures
The big aluminum box sure does fill the rear end up!!
12-06-2018, 05:28 AM
NH
Craig
You making tanks?
12-06-2018, 02:20 PM
va
Originally Posted by 1985 CCX
Craig
You making tanks?
Hey Jeff
I sure do, you need one?
01-05-2019, 09:48 AM
va
Now that the holidays are out of the way it's time to get cracking on this build.
Had a huge delay with my powder coating guy but I think we are back on track now.
Engine time,
mounted the fuel filter assembly finally ( powder coating delay) then made up some nice stainless lines.
Double flare AN ends.
01-11-2019, 06:54 AM
va
Fuel lines for the engine finished, fabricated the fuel log to feed the race bowls for the Holley.
Made up the bracket to mount the oil filter adapter.
Got the alternator mounted, pulleys spaced correctly.
Started working on something to fit behind the cover under the alternator.
01-20-2019, 11:51 PM
MN
Nice tank. Question, did you TIG weld the tank, or torch? The cleaning lines look so nice that my novice eyes can't tell.
01-21-2019, 08:46 AM
UK
Cobra Make, Engine: DB427SC. 289FIA. COUPE. Round tube, Aluminium body, 427FE
Will that alternator pulley clear the suspension tower?
Beautiful work as always. ;-)
01-21-2019, 09:04 AM
Full Blown Member
I'm sure Craig will chime in but in my case, I have my alternator down low in that location due to the Twin Paxtons. Get the right size belt and there's ample space.
rodneym
01-21-2019, 03:30 PM
va
Thanks
I use a Tig.
01-21-2019, 03:33 PM
va
The hipo alternator pulley should just sneak in there I believe.
We should know for sure very soon
02-23-2019, 06:19 AM
va
Next up, making the remote oil filter and cooler lines.
Also making the fuel lines up.
02-23-2019, 09:56 AM
NY
Looking nice Craig. The thing I dread the most is making oil lines and fuel lines, it is too easy to get them too long an have to cut them back, or even worse, too short  . Also, with the braided steel ones invariably my fingers become sore due to the puncture wounds from loose steel wire braids.
Jim
02-26-2019, 05:52 PM
Wheels came out better than I could have imagined. So nice that I treated them to a new set of Avons...
Cobra should be on the ground over the next few weeks. Can't wait!!
02-27-2019, 05:19 AM
va
The wheels turned out great, it was an exciting day to see the wheels finished and mount the new rubber.
Here is a couple more pictures of the wheels.
02-28-2019, 01:44 PM
va
Next up are the rear wheel inner fenders.
This side is just about wrapped up.
03-01-2019, 03:46 AM
nj
Cobra Make, Engine: Self built (Aircar)
what is the coating used on those wheels it is awesome, ???
03-03-2019, 06:35 AM
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
On the fuel flare, I thought I was the only person to cheat the stainless to AN.
With the seam, I couldn't get a regular AN flare to seal, so I played with it and did a double flare (I think those are 45 degrees) then "fixed the angle with an AN (37 degree, but going from memory I may have the 2 swapped) flair tool.
I had quite a bit of these. My car is EFI and I wanted all fuel lines except a few feet for flex from the frame to engine to be 3/8" stainless. I didn't trust aluminum tube to not workharden then crack. At 40psi, a crack can spray a LOT of fuel.
So, were you able to find a tool to make a double AN flare, did you correct the angle with a second flare tool, or just leave the flare the wrong angle?
Thanks for all the pics. Glorious!
03-03-2019, 06:56 PM
va
Thanks, we like the outcome as well on the wheels.
The coating is a powder coating we came up with.
