14Likes
01-28-2022, 02:03 PM
Appreciate your replies
thanks to all for your insights.
I will be exploring costs and delays for ordering a new CSX car.
Brian
01-28-2022, 04:40 PM
Abnormal CC Member
Brian
If you are getting a new CSX car, you should probably read this: KMS Differential Questions
01-29-2022, 03:26 PM
Cobra Make, Engine: Alloy Shelby CSX 8057/Kirkham 1010, 289 Vintage Lykins Build
Originally Posted by 1ntCobra
I think this pertains only if getting an alloy CSX (i.e. a Kirkham based car).
If the OP wants an alloy CSX, there are a few coming into Shelby inventory via Kirkham in the near term (this year). I think fiberglass cars are into 2023 now.
Prices, as well, are rapidly escalating. Several recent price increases.
01-29-2022, 03:47 PM
Thank you for the info.
How / where do I find more details?
01-29-2022, 04:34 PM
NV
Check with a dealer. Hillbank has lots on their site. Becker used to be a pretty big dealer with good inventory, don't know if he is any more.
CSX4005LA
01-29-2022, 05:55 PM
PM me and I will put you in touch with a very knowledgeable and connected Shelby CSX dealer. Access to all the current CSX options (2000,3000,6000,7000,8000,9000).
The Hillbank inventory listed on their website is primarily Superformance except for one fiberglass 289 (CSX 8000) and two alloy Daytona Coupes.
01-30-2022, 06:18 AM
Abnormal CC Member
From my reading of the thread about the KMS differential, it seems that the KMS differential is an option for both CSX continuation cars (aluminum or fiberglass) as well as for the Superformance cars. The option is obviously not called the KMS differential when you order the car, it is probably called something like the optional alumunium differential. It seems that if you pick that optional differential that you want to make sure it is installed correctly to make sure it does not self destruct.
It seems that some aluminum CSX cars are complete Kirkham rollers from Utah, you do not need to worry about those because Kirkham will obviously install their differential correctly. Other alumimum CSX cars can start off as a Kirkham body/frame with most other assemby in Africa. Fiberglass CSX cars are also mostly assembled in Africa too. So if you order the optional differential, you should definitely make sure that it was installed correctly, because it seems that SAI, Hi-Tech, Hillbank or whoever have installed the optional differential in such a way that it dumps all of the fluid on the street as you drive. Maybe by now they have learned to install the optional differential correctly, but I would not count on it.
The differential thread started in 2017. And yet it continued.
Did they learn to install the differential correctly by 2019? KMS Differential Questions (this link starts at post 1461140) I will give you a hint, the answer is NO.
Did they learn to install the differential correctly by 2020? KMS Differential Questions (this link starts at post 1485154) I will give you a hint, the answer is NO.
01-31-2022, 12:10 PM
The Kirkham diff (identified by Shelby as a "Shelby 3.54 original style Differential") is included as standard for the CSX (aluminum and fiberglass), at least for the leaf spring (CSX 8000).
On the other hand, the KMS diff is an option for the Superformance, at extra cost. ("Upcharge for aluminum Salisbury type Diff (replaces ZF))
Thus, if you receive a CSX it makes sense to check the diff venting configuration regardless, as the diff is a KMS (but not assembled by Kirkham).
02-01-2022, 01:07 AM
1ntCobra
“So if you order the optional differential, you should definitely make sure that it was installed correctly, because it seems that SAI, Hi-Tech, Hillbank or whoever have installed the optional differential in such a way that it dumps all of the fluid on the street as you drive. Maybe by now they have learned to install the optional differential correctly, but I would not count on it.
Did they learn to install the differential correctly by 2020? KMS Differential Questions (this link starts at post 1485154) I will give you a hint, the answer is NO.[/quote]”
Unfortunately, they have not learned how to install the differential properly, nor have they learned the proper use of fasteners (nuts, bolts and washers) in high load / shear applications.
02-22-2022, 02:48 AM
SW Dynamic Motorsports and Shelby Cars NW
First, I again want to thank everyone here for the responses to date on this thread. Very helpful and informative.
If I place an order for a CSX, I will be doing so a considerable distance from whichever dealer I use.
So now, I would like to invite posts or PMs from anyone that can comment on their personal experience with Mark Logan of SW Dynamic Motorsports and Shelby Cars NW.
As I understand it, he previously ran his dealership from Portland, OR. And now operates from the Dallas / Fort Worth area.
All comments welcomed and appreciated. Particularly those from owners who took receipt of their cars and then sorted them from a distance from Mark Logan and his dealership.
Again, many thanks for the fantastic community that you have created here.
~Brian
02-22-2022, 06:25 AM
SC
~Brian
Brian,
If you live in the northwest, why would you not by from someone closer than Dallas, Tx?
Bill S.
02-22-2022, 08:56 AM
NV
Originally Posted by mrmustang
Brian,
Bill S.
Yeah, like Denbeste in northern CA who has them in stock and stacked on racks on the wall.
CSX4005LA
02-22-2022, 11:05 AM
Abnormal CC Member
Brian,
Bill S.
His profile says VT. I am pretty sure that is northeast.
