Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 10-20-2006, 08:01 PM
Clois Harlan's Avatar
Romanbuilt,
My guess your levers are slipping on the rod that runs parallel to your fire wall. I would suggest that either you spot weld them in place or drill a small hole thru the lever and rod and use a roll pin once you get everything in the position you want.
Clois
"Let's roll"
"Be part of Something Good
