| 29 |
12-10-2009, 08:45 AM
Banned
Question on installing brake lines/fittings...
I bought some braided brake lines from Olthoff's (with the proper fittings for my SPF) a few millennia ago and will probably use the wet(ter) winter months to finally tackle this.
Any tricks that I need to know (i.e. do you use a teflon paste/tape for sealing to the caliper)? I've done brakes a gazillion times on cars but have never R&R'd a brake line.
Thanks for the advice,
-Dean
12-10-2009, 10:11 AM
KY
Nope, no sealer. The fittings in the calipers are usually flared or pipe thread. Braided hoses usually use AN fittings.
Just make sure the fittings are the correct size, pitch, flare, etc.
12-10-2009, 10:55 AM
Cobra Make, Engine: Everett-Morrison, 429CI
My calipers are Wilwoods and the calipers are tapped to 1/8-27 NPT. I used a 1/8-27 to -3AN male adapter. Then -3AN SS brakelines to the hardlines on the frame. For the 1/8 end into the caliper I used a little red Loctite. The adapters are cadmium plated steel the calipers are aluminum. I made the choice that a sealer was better than over tightening the pipe thread. I have no leaks.
12-10-2009, 11:19 AM
Banned
That's sort of where my mind is at, too. Just want to gather as many opinions on the subject, thanks.
-Dean
12-10-2009, 11:53 AM
Dean many use an adapter part of which is NPT on one end and AN-3 on the other, no sealer is used, mechanical seal entirely. On some calipers the attaching hole is a straight thread and uses a Banjo bolt with copper or aluminum crush washers on either side of the Banjo itself.
12-10-2009, 01:11 PM
Banned
Rick, that may be what I have here. Adapter to the factory Wilwood calipers was provided. It's a straight fitting (i.e. no banjo...I'm familiar with how those work).
My thinking is if you use sealant for the pipe threads on a mechanical fuel pump, why wouldn't you do the same with a brake line that is also carrying a thin fluid that is under pressure?
-Dean
12-10-2009, 01:52 PM
Cobra Make, Engine: Superformance 460 SVO
Dean make sure you use a good flare nut wrench. I used the flex head ones from Griot's. the fittings on the hard line are a bear to get to.
12-10-2009, 02:19 PM
Banned
Cal, thanks for the heads-up. I might even hit all of them with a little shot of PB Blaster the night before just to loosen them up some.
12-10-2009, 02:30 PM
Dean, another thing , on the rubber hoses to the calipers, the fitting were pretty tight on mine, I just cut the hose off at the fitting, and stuck a socket on them to take them out. didn't want to round off the fitting.
12-10-2009, 03:46 PM
Banned
Yes, I thought about that, too. The old hoses aren't going back on, and it's not like someone else is game enough to install old brake lines (though I could be wrong on that one!).
12-10-2009, 04:10 PM
Dean,
I installed the Olthoff braided lines on #1938, shortly after getting the car on the road in early 2005. I didn't use any sealer or tape and haven't had any issues since. I believe the experts advise against using sealer/tape, but for what reason I don't know. You might call Dennis and ask for his advise.
Jim Woodard
12-10-2009, 04:13 PM
Because sealant will make a joint more forgiving if there are tiny mechanical discrepancies... up to maybe 100 psi or so.
At the thousands of PSI in a brake system, you have it mechanically perfect or it's going to leak. You hope all it does is leak...
