SUPPORT OUR SPONSOR
Old 02-08-2010, 05:24 AM
Cobra Make, Engine: jbl
Originally Posted by Ant View Post
After doing a bit of research, Castrol or any other coy make moly extreme pressure grease for CV joints, Redline make CV2 grease which is red moly and synthetic with good feedback, which I will use.
I am going through the process of changing my inner plunge joints to Porsche 930 108mm joints as the previous ball and cage joint had the circlip in the wrong place so I thought I had better find a good grease for racing use, one positive all my chromemoly CV's have small boots on them now so less chance of coming off.
ant, you doing this to a ford 8.8 irs?
Old 02-09-2010, 01:19 PM
Ant Ant is offline
Default irs 8.8 cv grease
I want to do a bit of racing and I had 300m bars and chromemoly cv axles made up 2 years ago and when I came to fit them the circlip position on the inner cv was for a GTO not Ford, so the supplier kindly exchanged the inner cv for there latest Porsche 930 units.
The inners they supply are ball and cage, compared to the tripod ford joint which is still ok for most use, the Porsche unit is stronger again and if it packs up just unbolt the joint and fit a new one without changing the whole unit.
A J. Newton
The 1960's rocked!
HTML code is On
