SUPPORT OUR SPONSOR
Old 06-08-2010, 09:41 AM
kitcarbp's Avatar
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Bending 304 Stainless 1/2" Fuel Line ?
ok folks, before I purchase some 1/2" 304 stainless fuel line I need some advice on hand formability from those that have worked with 1/2" 304 fuel line. I am making a hard line from fuel pump to the fuel tank. Total length will be about 4 feet. My plan is to use 0.028" wall thickness and buy seamless 304 tube from Graingers down the street. Is this the right grade and wall thickness to use ? Other SS in the aftermarket is 304 tube welded and drawn compared to seamless i am thinking of.
I have bent many 3/8" fuel lines and vacuum lines before in mild coated steel. I need a bend in the 1/2" stainless line by hand down to a radius of about 5" for my application. I have "spring benders" for tube bending that you slide over the tube, this works great for 3/8" lines IMHO. Will the spring benders also work for 1/2" SS 304 ? Feedback on what youve done is appreciated.
Thanks
"...some assembly required, ages 8 and up...... well that took longer than expected......
Old 06-08-2010, 10:11 AM
FWB's Avatar
FWB FWB is offline
yes seamless is good, but a 304L would make life easier. look at mcmaster-carr if grainger's doesn't list it. or "the micro group" (All Tube). hand forming may collapse, borrow a conduit bender.
Old 06-08-2010, 11:17 AM
Jerry Clayton's Avatar
Altho I have benders for tube bending---if you need a 5 " radius--you probably can do it with a over spring and a v belt pulley that is about 9 or 10 inches in diameter--9 inches because of springback--- anneal the end before flaring
Old 06-08-2010, 02:44 PM
mickmate's Avatar
Seamless for flared ends, annealed for formability. That's a big radius so shouldn't be a problem.
mickmate
http://www.actoncustom.com/
Old 06-08-2010, 10:58 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
I think installing a SS fuel line is a great idea. Hope it goes well!
Old 06-09-2010, 10:24 AM
kitcarbp's Avatar
Thanks guys, I'll post pics when I am done fabricating it back here on this thread. I read that the "low carbon" 304L spec is typically used when welding heavy gauge stainless plate, most tube is just 304 so far that I could find readily available.
HTML code is On
