February 2026
Old 09-23-2012, 12:20 PM
bubba622's Avatar
Cobra Make, Engine: 1990 LA EXOTIC (although i'm not quite convinced yet)
Default Ford Power Steering Rack part #
I have a Ford (stamped in the casing) power steering rack which needs replacing, the number on the casing is G 26 TFC 2, i cannot find a reference to this number in any of the dozens of places i've searched...Does anybody have any idea as to how to locate a replacement for this item...any direction would be much appreciated.....
Old 09-23-2012, 12:25 PM
Rick Parker's Avatar
That is not a part number. FYI most of the Ford power steering racks used in Cobra Replicas are sourced from 74-78 Mustang II.
FWB's Avatar
FWB FWB is offline
the ford reference number was affixed via a tag, not the casting number on the housing. if it indeed is a ford, it could be maybe one of three different ones. mustang II, t-bird, pinto......a picture would help..
Fred B
Old 09-23-2012, 12:54 PM
FWB's Avatar
FWB FWB is offline
the mustang II will have 3 bolt mounting, if you measure center to center, 12" for the inboard and 16" to the outboard.
pinto rack will be a clamp on.
Fred B
Old 09-23-2012, 04:47 PM
bubba622's Avatar
Default photo of rack
I have attached a photo as requested, i also removed the band around the rack, the number on it is U788 1089, does this help anyone at all
Old 09-23-2012, 05:37 PM
FWB's Avatar
FWB FWB is offline
yes it's a Ford rack....measure the mounting bolt distances and if you get the measurement i posted its mustang II....
Fred B
Old 09-23-2012, 07:50 PM
PANAVIA's Avatar
Does not look bulky enough to be a mustang II - could be escort ....
As the others have stated , some measurements and turns lock to lock would help to unravel the origin -
Old 09-27-2012, 06:11 AM
joyridin''s Avatar
Doesn't look like a M2 to me either. Looks closer to the rack I had in a 1984 Mustang. The newer racks have a cast housing. This is steel 2 piece design.
Old 09-27-2012, 08:31 AM
If memory serves me right the Mustang II racks with Power Steering had 3 mounting points and those without had 2 mounting points, similar to the ill fated Pinto, which is the same design and can be used, but the ratio is pretty slow.
Old 09-27-2012, 09:00 AM
FWB's Avatar
FWB FWB is offline
Rick,
i guess your memory isn't serving you....even from 4 posts ago.
factory mustang II has 3 mounting flanges whether its power or manual.
pinto clamps on....2 spots....
a pic from the top is not good enough for a determination.
the crossmember looks like it is a factory ford mustang II.
it is a ford rack..............
it may or my not be mustang II. to measure the mounting will tell you if it is or isn't
it is not Fox body mustang or late model t-bird..
Fred B
