SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-14-2013, 05:13 PM
GTBill's Avatar
Cobra Make, Engine: Superformance -Roush 427R
Default Superformance made me walk home !
Went out for a ride last night and heard a "POP' from the rear of the car. Then quickly noticed the engine increased RPM and speed was dropping off. -Busted Axel, CV Joint-Differential are OK. Happened in traffic at 40mph.
I had heard SF was having axel issues in the older cars but mine is an '06 build. Boo Ho.
So, any one with any repair suggestions or valauable information ?
Old 04-14-2013, 05:45 PM
Cobra Make, Engine: Superformance #678
Bummer bud, hope it does not happen to my #678
Old 04-14-2013, 06:34 PM
Cobra Make, Engine: Superformance #522
Where exactly did it break? The Thunderbird IRS is very reliable in these cars unless you are dropping the clutch with more than 550 ft/lb and sticky tires. There are stronger aftermarket axels available if needed. Www.driveshaftshop.com
Old 04-14-2013, 09:35 PM
Got the Bug's Avatar
What's your chassis number?
Doug
Old 04-14-2013, 10:51 PM
WardL's Avatar
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
I wonder what the failure mechanism was. It is hard to imagine an axle snapping when you are just driving along, but I'm clueless about how this might happen. You mention the RPM increased, but wouldn't the limited slip keep the good axle pushing the Cobra? I lost a wheel bearing last summer and wondering if I should have inspected the axle a little closer. Do you have any pictures? Good luck pulling everything and getting it back together! It was a bit of a challenge for me, but with the help of Randy Thomas and my installer I was able to replace both wheel bearings.
Old 04-14-2013, 11:36 PM
LMH's Avatar
LMH LMH is offline
Call the Driveshaftshop and talk to them about some new axles. Best to send them your old ones and have them rebuild both with 300M center shafts.
Alba gu brąth
Old 04-15-2013, 05:32 AM
mrmustang's Avatar
Gold Star Contributor
Neutral
Do we need to trailer it somewhere? I'll be around all week (on and off) if you need some help.
EDIT: I remember someone else with an earlier car who got replacement axles from http://www.driveshaftshop.com/
Bill S.
Old 04-15-2013, 08:16 AM
DanMartin's Avatar
Cobra Make, Engine: Superformance Cobra Chassis #408, 427FE, TKO600
I have replacement axles from DSS on #408. Happy with them....quality item. They have the measurements on-file so it's a quick order.
I had to get different nuts for the outer axle as the ones that DSS ships have a shoulder that is too wide for the spinner adapter on the SPF...so be aware. I got mine from SPF, but I think they are just standard Ford t-bird part. I think they were like $10 each.
Old 04-15-2013, 12:38 PM
Hello GTBILL
Sorry about your trouble.
You must live really close by
JB
Old 04-16-2013, 01:28 PM
GT Bill's Avatar
Cobra Make, Engine: Superformance - Roush 427R
Thanks Guys, a lot of good info......
I have #2379 with the Dana rear. I don't know how to post pictures but the axel failure looks to be a poor "Heat Treat" after splineing . There is no evidence of twisting.
In response to dropping the hammer. At 5K RPM, with sticky tires -no - at least not this time. Thanks to the application of a Demon 750 carb -good tune , I am getting 522Hp / 505FP Tqe at the rear wheels on the Dyno Jet. (Roush 427R circa 2006).
Thanks Mr.Mustang , haven't seen you since last fall at Beans Ford.
Yes JB we must be close ---I am near the Seven Stars Rest.
I am in contact with DSS in N.C. Seems they are over a month out just to assemble. Geeeeeze !
Old 04-16-2013, 02:32 PM
mrmustang's Avatar
OUCH!!!!!!!!!!
I might take yours in trade towards my FIA, you could be on the road tomorrow
Bill S.
Old 04-16-2013, 02:50 PM
GT Bill's Avatar
That's cold Bill!
My "Extra Tight Pal" Dennis Olthoff is trying to get one here by Friday.
Ya know, You could put the "Blue Light Special" on the FIA and I'll put in the garage as a spare !
Bill
Old 04-16-2013, 05:29 PM
If you're getting 522 hp at the rear wheels, something back there is bound to eventually twist in half.
Jim
Old 04-16-2013, 06:06 PM
mrmustang's Avatar
That's cold Bill!
Bill
Make me an offer, the worse that can happen is that I say NO.
HTML code is On
