SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-19-2001, 09:45 PM
Default Help identify this front cover -
Part number: E0AE-6059-AA. I believe it's a front cover off an '80 or '81 351W. I tried to bolt up my new Edelbrock mechanical fuel pump (#1725) tonight but the pump is contacting the bottom corner of the front cover. It seems I may need to grind off about 1/4 inch of the lower corner of the front cover to get the fuel pump to fit. Anyone else run into this before?
Thanks.
Old 11-21-2001, 01:00 PM
Seems some guys over at corral.net have run into this before. The solution is as I suspected: I'll need to grind down the bottom corner of the timing cover. I'll let you know if Edelbrock has a different solution.
Old 11-21-2001, 03:30 PM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
I also have this problem with the Edelbrock fuel pump. The problem was solved with an angle grinder.
Regards,
Bryan Wilson
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
HTML code is On
