| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
2Likes
Post By Rick Parker
Post By patrickt
11-11-2014, 06:08 PM
Ca
Tedious afternoon
For the last few weeks I've had the steering gear out of the car and servicing the Steering Rack and front suspension. To access some of the fasteners to redo the safety wire I had to remove the radiator. Today I spent the biggest part of the afternoon on a thankless menial project; straightening the fins on the radiator. Damn that is so tedious. I purchased a Fin Comb and before using it was then told by the folks at Fluidyne to use a pick instead and to not to go to deep as damage to the louvers would hinder the efficiency of the radiator. The trick is to carefully slide the pick in between each fin (about 1/4" deep) that has been folded over by road debris, large bugs and ingested import cars  and work it from top to bottom between the horizontal tubes. Then using very long pointed needle nose pliers I was able to flatten the metal fins between the tubes and essentially reshape the damaged ones. I was amazed how long it took. There's ALOT of rows on a radiator
Rick
Advertising
11-11-2014, 06:13 PM
That's why I like pusher fans -- they deflect a lot of the road debris.
11-11-2014, 06:47 PM
ca
Cobra Make, Engine: SPF #1473 392 cu.in. titanium/black stripes
Except I don't recall seeing them on slabsides...
Bob
"Outside of a dog, a book is man's best friend. Inside a dog it's too dark to read."
Groucho Marx
11-11-2014, 07:13 PM
Ca
I'm going to be getting Foam for my rollbar (NOT!), oh wait I never saw that on 289's either....
Rick
11-12-2014, 02:03 AM
OR
It'll look better too, rick! Go get em'!
ERA FIA 2088
11-12-2014, 09:57 AM
Ca
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Actually the original fan on a 289 street Cobra was a pusher fan.
11-12-2014, 02:37 PM
Full Blown Member
...as well as air.
rodneym
11-12-2014, 02:43 PM
Originally Posted by rodneym
...as well as air.
... but they also keep your speedometer needle from bouncing.
11-12-2014, 03:24 PM
Ca
Patrick:
Increase the pitch on the props.
Rick
11-12-2014, 03:42 PM
Originally Posted by Rick Parker
Patrick:
But then I might need a sign like this:
11-12-2014, 04:01 PM
Full Blown Member
Naaaaw.
Nuthin' a couple well placed foam tubes couldn't fix
rodneym
11-12-2014, 04:29 PM
ks
Cobra Make, Engine: Kirkham 557
Rick...we have huge grasshoppers in the Midwest where I live. I spent a similar amount of time that you did extracting grasshoppers/butterflies and large bugs of indeterminate origin from the radiator and oil cooler and then straightening radiator fins. Then I bought one of these radiator guards, painted it black, and trimmed it to fit the radiator and oil cooler. It's a press fit in both locations. You can easily remove the guards and hose the bugs out from the back side. The guards can be easily removed in less than 5 minutes for car shows, etc. No more bent fins!
11-12-2014, 04:31 PM
ks
radiator guards
My apologies...forgot to include the link in my previous post. You can buy them at Summit or directly from the manufacturer.
http://www.summitracing.com/parts/ky...FQinaQodojoAnw
11-13-2014, 07:04 PM
OH
Cobra Make, Engine: ERA 714
Tedious Afternoon
I have found that an air hose with a limited amount of pressure works well.
Phil
| Thread Tools |
| Display Modes |
Linear Mode
HTML code is On
