SUPPORT OUR SPONSOR
Old 12-31-2001, 07:14 AM
bran3b's Avatar
Cobra Make, Engine: Midstates, 460
Default hole in 460 block
I am planning to start my 460 for the first time tomorow (1/1/02), but I can't figure out what the hole at the back of the engine block goes to. The hole is just behind the intake manifold, in the center of the block. I think that it goes into the lifter valley, but I want to be sure before I plug it and cause problems.
Please help, I HAVE to start the car tomorow, sitting in it and making VROOM VROOM noises aren't good enough any more .
Thanks,
Bran
"Clowns to the left of me,
Jokers to the right..."
Brandon
Old 12-31-2001, 07:30 AM
Default Hole in Block
The hole in the block behind the manifold is the port for measuring oil pressure. You can plug it with an 1/8 NPT plug or hook up an oil pressure sending unit to it and use a gage.
Do something to it before you start the engine or you will have a mess to clean up.
Old 12-31-2001, 07:32 AM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
It's a secondary port for oil pressure sending units, mostly used on vans and other applications where space on the lower left is tight. You can plug it with an NPT fitting or use it for a secondary low pressure signal--ie; a light to compliment a gauge.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 12-31-2001, 08:22 AM
bran3b's Avatar
Default Thanks
Thanks for your reply guys, now I have hope again. If all goes well, I will be on the road tomorow afternoon.
Thanks again,
Bran
Brandon
HTML code is On
