SUPPORT OUR SPONSOR
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Like Tree2Likes
  #21 (permalink)
Old 07-16-2016, 11:54 PM
Buzz's Avatar
Originally Posted by redmt View Post
Parking brake lives in another part of the rear and the calipers have one piston per side for 2 each caliper.
John, can you share some details on the parking brake setup that you are using?
Tropical Buzz
  #22 (permalink)
Old 07-17-2016, 07:38 AM
joyridin''s Avatar
I have a pinion mounted unit on mine from a Ford 9" that i modified using parts from a kit Speedway sells. It will hold the car on an incline and bring it to a stop over a longer distance, but it will not hold it during acceleration.
  #23 (permalink)
Old 07-17-2016, 07:47 AM
Buzz's Avatar
Thanks Joyridin' looking at options before ordering a (very pricey) set of calipers with the standard Jag IRS parking brake setup included.
Tropical Buzz
  #24 (permalink)
Old 07-17-2016, 08:00 AM
Buzz what I meant was that the parking brake wasn't part of the min calipers but a separate stock mechanical type caliper.
I'm going to look into the pinion brake. That sounds like it may be a viable alternative to the more complicated stock Jag setup.
  #25 (permalink)
Old 07-17-2016, 10:01 AM
joyridin''s Avatar
If you need the parking brake set-up, let me know. I have a few sets with the pawls with all the hardware including pads. You would need a cable as they are probably different for most cars, but that should be easy to do.
Display Modes
HTML code is On
