SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-09-2021, 09:19 AM
FUNFER2's Avatar
Wow, you'd think it should a perfect line to lesson vibration and keeping in sync
with each other.,
Regards,
Kevin
Old 07-10-2021, 05:50 PM
Cobra Make, Engine: CMC,Ford 302
Does it matter if dif is higher than trans? My engine drop is 3° down and my dif is 3° up but dif is higher than output shaft of trans.
Old 07-11-2021, 05:19 PM
Tom Wells's Avatar
Don,
Doesn't matter.
As long as the centerline of the pinion gear and the centerline of the crankshaft/trans assembly are parallel, the car will be fine.
The direction of the offset isn't a factor. Up or down, left or right - take your pick.
Tom
Old 07-11-2021, 10:27 PM
Wont matter unless the pinion climbs ring gear. In that case it will get more up pinion angle. If it gets too severe it will brake the rear u joint. Under acceleration you will start to feel it binding. I dont know what type of rear setup have but if there is rubber mounts or bushings or parallel leaf springs you would be better off with the pinion set at 0 degrees.
Old 07-12-2021, 07:22 AM
FUNFER2's Avatar
So, lets start with the engine placement.
How do I find out where the engine is placed front to back & left to right ?
I would ask the new owner of my replica company, but he's an idiot and there's
virtually no.owners on their forum to talk to, and I don't know why other than the owner.
Regards,
Kevin
Old 07-12-2021, 11:04 AM
What trans is in it now? If its a stick are you going to reuse the tranny? If so you will need a different bellhousing. You will then mount the trans in the same position it is now. You will then align the engine straight in the chassis as it is now even if its offset to one side or the other. Then the mount for the engine can be made to duplicate the engine trans angel you have now. If its an auto you will be changing that too. But say for instance you were using a c 6 on the Fe and you are going to use a c6 on your new motor it s going to take a different trans. But if its the same length tailhousing and mount location you will mount it in the same location as the old one. You should be able to use your old drive shaft in both cases. In both cases above you will align the engine the same way.
Old 07-12-2021, 11:21 AM
FUNFER2's Avatar
Oh no, always a stick (Tremec TKO 600) unless mine is a Super Snake. lol Yep, I need a new bell and maybe a fork ?
Regards,
Kevin
Display Modes
HTML code is On
