SUPPORT OUR SPONSOR
Old 03-16-2002, 01:14 PM
Default Contemporary Coilover front end shims
Would any Contemporary owner/builder be able to identify/source the factory built front end shims for the coilover front suspension. Im looking for a shim which is about one inch wide and about three and three eights inches long with a slot about three inches long. The standard automotive shims are tough to work with and look sloppy in this application.
With appreciation, Jack.
Old 03-16-2002, 01:28 PM
John McMahon's Avatar
Cobra Make, Engine: SOLD: 2013 Boss 302 Mustang #2775 (both options). SOLD: 95 Mustang Cobra R #4 of 250 "Rosie's Diner" car. SOLD: CCX2-2505, #5 of 7 289 FIAs ever produced at Contemporary! my first Cobra: Unique 427SC w/ 428CJ moder!
Jack,
Check with Bill Connelly at Upstate Super Replicars. His Daytona Coupes were originally from Contemporary and utilize the same coil over front end and frame.
Here is the website:
http://www.daytona-coupe.com/
REMEMBER....In Case of Spin....Both Feet in!!!!!
Old 03-18-2002, 02:54 PM
Cobra Make, Engine: Contemporary, 427 EFI; CAV GT40, 427W
I have this setup. Where does this shim go?
Thanks
Gary
CAV GT40 Dealer
www.2gmotorsports.com
Old 03-20-2002, 06:44 PM
CCX..... These shims are installed in between the upper control arm and the stantions that rise from the 4in. main frame rail tubing, thereby allowing for front end alignment.
CCX 3-3806
Jack Mack
Old 02-26-2007, 05:45 PM
Default Alignment shims
Hi Jack,they are from an E type Jag,check your Jag dealer or somebody who works on E types and they should be able to supply you the shims.
rgds,Mike.
Old 02-28-2007, 06:44 PM
767Jockey's Avatar
Try www.sngbarratt.com
They're a huge British supply house for all parts Jaguar related, and they have a big operation here in America in Manchester, New Hampshire. Go on the website and click on the link for USA business. Or, if you prefer you can call them at 603-622-1050. I got all the parts to rebuild my Contemporary torsion bar based Jaguar front end from them. Good luck!
Doug
Old 02-28-2007, 07:39 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
I had my intake manifold ceramic coated outside in bright polished alluminum and inside with another coating. has worked great for the last seven years. and cheaper than polishing.
Mike H
HTML code is On
