SUPPORT OUR SPONSOR
Old 03-23-2002, 07:31 PM
Default Oil pressure sending unit problems
We finally got our fuel leak problems solved and we were going to fire the car up but we had a problem with the oil pressuge gauge. When I spun the oil pump with my drill ( in reverse ) I noticed that no oil pressure was indicated on the gauge. The accusump charged up fine and the oil pressure fuel cut off switch functhion as expected. We test the sending unit wire by putting a 1.5 volt battery on it and sure enough we got a reading on the OP gauge. The gauge and sending unit are Stewart Warner.
Any one have any suggestions on what I should do next?
Thanks for your help,
Roger
Roger
Old 03-23-2002, 07:48 PM
petek's Avatar
Cobra Make, Engine: CRL, 351W, Tremec TKO
You might try disconnecting the sender from any other wiring then place an ohm meter between the sender and ground. Look for a change in resistance when you spin the oil pump up.
Pete K.
Who is John Galt?
Old 03-24-2002, 04:30 AM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Roger,
Sounds like a bad sender, but check out this old link for more info than you'll probably need....
Oil Temp Gauge problems
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 03-24-2002, 07:30 PM
Pete and Jim,
Thanks for the advice. We will try to find the problem tomorrow.
Roger
Roger
Old 03-26-2002, 06:15 PM
We found the problem. The unit was not grounded properly.
Thanks for the help.
Roger
Roger
HTML code is On
